IP DHCP Relay on Tenant EPG
You can configure DHCP Relay Server and Gateway Configuration per tenant network.
IP DHCP relay agents are used to forward requests and responses between the DHCP clients and the DHCP servers when they are not on the same physical subnet.
IP DHCP relay agents trap the DHCP messages between the DHCP clients and the DHCP servers and generate new forwarding message.
DHCP Client, DHCP Server, DHCP Relay
DHCP Relay Messages
MultiRack Topology with DHCP Server, Client and Relay
