In EFA versions prior to 3.0.0,
running the REST GET API or the equivalent CLI without tenant filter disables
the tenant admin to view the resources or entities owned by the tenant admin and the
resources or entities owned by the shared tenant.
In EFA versions 3.0.0 or above,
running the REST GET API or the equivalent CLI without tenant filter enables
(efa:root)root@administrator-00:~# efa tenant show +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ | Name | Type | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD | Ports | Mirror Destination Ports | +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ | roottenant | private | 2-20 | 10000-10099 | 10110-10119 | 10 | false | 10.20.246.4[0/20] | 10.20.246.4[0/21] | | | | | | | | | 10.20.246.3[0/20] | 10.20.246.3[0/21] | +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ | sharedtenant | shared | 2-20 | 20000-20099 | 20110-20119 | 10 | false | 10.20.246.4[0/22] | 10.20.246.3[0/23] | | | | | | | | | 10.20.246.3[0/22] | 10.20.246.4[0/23] | +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ | t1 | private | 2-20 | 30000-30099 | 30110-30119 | 10 | false | 10.20.246.4[0/24] | 10.20.246.3[0/25] | | | | | | | | | 10.20.246.3[0/24] | 10.20.246.4[0/25] | +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ | t2 | private | 2-20 | 40000-40099 | 40110-40119 | 10 | false | 10.20.246.4[0/26] | 10.20.246.4[0/27] | | | | | | | | | 10.20.246.3[0/26] | 10.20.246.3[0/27] | +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ Tenant Details (efa:root)root@administrator-00:~# efa tenant po show +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ | Name | Tenant | ID | Speed | MTU | Negotiation | Min Link | Lacp | Ports | State | Dev State | App State | | | | | | | | Count | Timeout | | | | | +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ | rootpo | roottenant | 2 | 10Gbps | | active | 1 | long | 10.20.246.4[0/20] | po-created | provisioned | cfg-in-sync | | | | | | | | | | 10.20.246.3[0/20] | | | | +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ | sharedpo | sharedtenant | 3 | 10Gbps | | active | 1 | long | 10.20.246.4[0/22] | po-created | provisioned | cfg-in-sync | | | | | | | | | | 10.20.246.3[0/22] | | | | +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ | po1 | t1 | 4 | 10Gbps | | active | 1 | long | 10.20.246.4[0/24] | po-created | provisioned | cfg-in-sync | | | | | | | | | | 10.20.246.3[0/24] | | | | +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ | po2 | t2 | 5 | 10Gbps | | active | 1 | long | 10.20.246.4[0/26] | po-created | provisioned | cfg-in-sync | | | | | | | | | | 10.20.246.3[0/26] | | | | +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ Port Channel Details (efa:root)root@administrator-00:~# efa tenant vrf show +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-----------------+-------------+ | Name | Tenant | Routing Type | Centralized Routers | Redistribute | Max Path | Local Asn | Enable GR | State | Dev State | App State | +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-----------------+-------------+ | rootvrf | roottenant | distributed | | connected | 8 | | false | vrf-device-created | provisioned | cfg-in-sync | +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-----------------+-------------+ | sharedvrf | sharedtenant | distributed | | connected | 8 | | false | vrf-device-created | provisioned | cfg-in-sync | +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-----------------+-------------+ | myv1 | t1 | distributed | | connected | 8 | | false | vrf-device-created | provisioned | cfg-in-sync | +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-----------------+-------------+ | myv2 | t2 | distributed | | connected | 8 | | false | vrf-created | not-provisioned | cfg-ready | +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-----------------+-------------+ Vrf Details (efa:root)root@administrator-00:~# efa tenant epg show +-----------+--------------+-------------+-------+--------+------------+-------------+------------+-----------+-------+------------------------------------+ | Name | Tenant | Type | Ports | PO | SwitchPort | Native Vlan | Ctag Range | Vrf | L3Vni | State | | | | | | | Mode | Tagging | | | | | +-----------+--------------+-------------+-------+--------+------------+-------------+------------+-----------+-------+------------------------------------+ | rootepg | roottenant | extension | | rootpo | trunk | false | 10 | rootvrf | 10111 | epg-with-port-group-and-ctag-range | | | | | | | | | | | | | +-----------+--------------+-------------+-------+--------+------------+-------------+------------+-----------+-------+------------------------------------+ | sharedepg | sharedtenant | l3-hand-off | | | | false | | | | epg-empty | | | | | | | | | | | | | +-----------+--------------+-------------+-------+--------+------------+-------------+------------+-----------+-------+------------------------------------+ | epg1 | t1 | extension | | po1 | trunk | false | 11 | myv1 | 30111 | epg-with-port-group-and-ctag-range | | | | | | | | | | | | | +-----------+--------------+-------------+-------+--------+------------+-------------+------------+-----------+-------+------------------------------------+ | epg2 | t2 | extension | | po2 | trunk | false | 12 | sharedvrf | 20111 | epg-with-port-group-and-ctag-range | | | | | | | | | | | | | +-----------+--------------+-------------+-------+--------+------------+-------------+------------+-----------+-------+------------------------------------+ EndpointGroup Details
(efa:t1user)root@administrator-00:~# efa tenant show +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ | Name | Type | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD | Ports | Mirror Destination Ports | +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ | sharedtenant | shared | 2-20 | 20000-20099 | 20110-20119 | 10 | false | 10.20.246.4[0/22] | 10.20.246.4[0/23] | | | | | | | | | 10.20.246.3[0/22] | 10.20.246.3[0/23] | +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ | t1 | private | 2-20 | 30000-30099 | 30110-30119 | 10 | false | 10.20.246.4[0/24] | 10.20.246.4[0/25] | | | | | | | | | 10.20.246.3[0/24] | 10.20.246.3[0/25] | +--------------+---------+------------+-------------+-------------+-----------+-----------+-------------------+--------------------------+ Tenant Details (efa:t1user)root@administrator-00:~# efa tenant po show +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ | Name | Tenant | ID | Speed | MTU | Negotiation | Min Link | Lacp | Ports | State | Dev State | App State | | | | | | | | Count | Timeout | | | | | +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ | sharedpo | sharedtenant | 3 | 10Gbps | | active | 1 | long | 10.20.246.4[0/22] | po-created | provisioned | cfg-in-sync | | | | | | | | | | 10.20.246.3[0/22] | | | | +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ | po1 | t1 | 4 | 10Gbps | | active | 1 | long | 10.20.246.4[0/24] | po-created | provisioned | cfg-in-sync | | | | | | | | | | 10.20.246.3[0/24] | | | | +----------+--------------+----+--------+-----+-------------+----------+---------+-------------------+------------+-------------+-------------+ Port Channel Details (efa:t1user)root@administrator-00:~# efa tenant vrf show +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-------------+------------+ | Name | Tenant | Routing Type | Centralized Routers | Redistribute | Max Path | Local Asn | Enable GR | State | Dev State | App State | +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-------------+-------------+ | sharedvrf | sharedtenant | distributed | | connected | 8 | | false | vrf-device-created | provisioned | cfg-in-sync | +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-------------+-------------+ | myv1 | t1 | distributed | | connected | 8 | | false | vrf-device-created | provisioned | cfg-in-sync | +-----------+--------------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-------------+-------------+ Vrf Details (efa:t1user)root@administrator-00:~# efa tenant epg show +-----------+--------------+-------------+-------+-----+------------+-------------+------------+------+-------+------------------------------------+ | Name | Tenant | Type | Ports | PO | SwitchPort | Native Vlan | Ctag Range | Vrf | L3Vni | State | | | | | | | Mode | Tagging | | | | | +-----------+--------------+-------------+-------+-----+------------+-------------+------------+------+-------+------------------------------------+ | sharedepg | sharedtenant | l3-hand-off | | | | false | | | | epg-empty | | | | | | | | | | | | | +-----------+--------------+-------------+-------+-----+------------+-------------+------------+------+-------+------------------------------------+ | epg1 | t1 | extension | | po1 | trunk | false | 11 | myv1 | 30111 | epg-with-port-group-and-ctag-range | | | | | | | | | | | | | +-----------+--------------+-------------+-------+-----+------------+-------------+------------+------+-------+------------------------------------+ EndpointGroup Details
