To enable external connectivity, you can configure the
send-community attribute when you create or update the BGP peer
group.
efa tenant service bgp peer-group create --name <bgp-pg-name> --tenant <tenant-name>
--pg-name <device-ip:pg-name> --pg-asn <device-ip,pg-name:remote-asn>
--pg-bfd-enable <device-ip,pg-name:true|false>
--pg-ipv4-uc-nbr-send-community <device-ip,pg-name:
all|both|extended|large|standard|large-and-extended|large-and-standard>
--pg-ipv6-uc-nbr-send-community <device-ip,pg-name:
efa tenant service bgp peer-group update --name <bgp-pg-name> --tenant <tenant-name>
--operation peer-group-add
efa tenant service bgp peer-group create --name ten1bgppg1 --tenant ten1
--pg-name 10.20.246.15:pg1 --pg-asn 10.20.246.15,pg1:55001
--pg-bfd-enable 10.20.246.15,pg1:true
--pg-ipv4-uc-nbr-send-community 10.20.246.15,pg1:standard
--pg-name 10.20.246.16:pg1 --pg-asn 10.20.246.16,pg1:55001
--pg-bfd-enable 10.20.246.16,pg1:true
--pg-ipv4-uc-nbr-send-community 10.20.246.16,pg1:extended
efa tenant service bgp peer-group update --name ten1bgppg1 --tenant ten1
--pg-name 10.20.246.15:pg2 --pg-asn 10.20.246.15,pg2:55002
--pg-bfd-enable 10.20.246.15,pg2:true
--pg-ipv6-uc-nbr-send-community 10.20.246.15,pg2:all
--pg-name 10.20.246.16:pg2 --pg-asn 10.20.246.16,pg2:55002
--pg-bfd-enable 10.20.246.16,pg2:true
--pg-ipv6-uc-nbr-send-community 10.20.246.16,pg2:both
efa tenant service bgp peer-group show --detail
Tenant : ten1
State : bgp-pg-created
Description :
Peer Group
Device IP : 10.20.246.16
Peer Group : pg1
Remote ASN : 65002
Next Hop Self : true
Update Source IP : 10.20.30.40
BFD Enabled : true
BFD Interval : 100
BFD Rx : 300
BFD Multiplier : 5
MD5 Password : $9$QxCvD7N6a0P96eT3BvnQfQ==
Remove Private AS : true
Prefix List In :
Prefix List Out :
Route Map In :
Route Map Out :
Send Community : standard (ipv4)
Dev State : provisioned
App State : cfg-in-sync
Peer Group : pg2
Remote ASN : 65002
Update Source IP : 10.20.30.50
BFD Enabled : true
BFD Interval : 100
BFD Rx : 300
BFD Multiplier : 5
Prefix List In :
Prefix List Out :
Route Map In :
Route Map Out :
Send Community : all (ipv6)
Device IP : 10.20.246.15
Peer Group : pg1
Remote ASN : 65002
BFD Enabled : true
BFD Interval : 100
BFD Rx : 300
BFD Multiplier : 5
refix List In :
Prefix List Out :
Route Map In :
Route Map Out :
Send Community : extended (ipv4)
Peer Group : pg2
Remote ASN : 65002
BFD Enabled : true
BFD Interval : 100
BFD Rx : 300
BFD Multiplier : 5
Prefix List In :
Prefix List Out :
Route Map In :
Route Map Out :
Send Community : both (ipv6)
Rack1-Device1# show running-config router bgp router bgp local-as 4200000000 capability as4-enable fast-external-fallover neighbor pg1 peer-group neighbor pg1 remote-as 65002 neighbor pg1 update-source 10.20.30.40 neighbor pg1 next-hop-self neighbor pg1 password $9$QxCvD7N6a0P96eT3BvnQfQ== neighbor pg1 remove-private-as neighbor pg1 bfd neighbor pg1 bfd interval 100 min-rx 300 multiplier 5 neighbor pg2 peer-group neighbor pg2 remote-as 65002 neighbor pg2 update-source 10.20.30.50 neighbor pg2 next-hop-self neighbor pg2 password $9$QxCvD7N6a0P96eT3BvnQfQ== neighbor pg2 remove-private-as neighbor pg2 bfd neighbor pg2 bfd interval 100 min-rx 300 multiplier 5 neighbor 10.20.20.4 remote-as 4200000000 neighbor 10.20.20.4 next-hop-self address-family ipv4 unicast network 172.31.254.214/32 network 172.31.254.228/32 neighbor pg2 prefix-list ipPrefixList2 in neighbor pg2 prefix-list ipPrefixList2 out neighbor pg2 route-map in routeMap2 neighbor pg2 route-map out routeMap2 neighbor pg1 prefix-list ipPrefixList1 in neighbor pg1 prefix-list ipPrefixList1 out neighbor pg1 route-map in routeMap1 neighbor pg1 route-map out routeMap1 neighbor pg1 send-community standard maximum-paths 8 graceful-restart ! address-family ipv6 unicast neighbor pg2 prefix-list ipPrefixList2 in neighbor pg2 prefix-list ipPrefixList2 out neighbor pg2 route-map in routeMap2 neighbor pg2 route-map out routeMap2 neighbor pg2 send-community all neighbor pg1 prefix-list ipPrefixList1 in neighbor pg1 prefix-list ipPrefixList1 out neighbor pg1 route-map in routeMap1 neighbor pg1 route-map out routeMap1 ! address-family l2vpn evpn graceful-restart ! ! |
Rack1-Device2# show running-config router bgp router bgp local-as 4200000000 capability as4-enable fast-external-fallover neighbor pg1 peer-group neighbor pg1 remote-as 65002 neighbor pg1 update-source 10.20.30.40 neighbor pg1 next-hop-self neighbor pg1 password $9$QxCvD7N6a0P96eT3BvnQfQ== neighbor pg1 remove-private-as neighbor pg1 bfd neighbor pg1 bfd interval 100 min-rx 300 multiplier 5 neighbor pg2 peer-group neighbor pg2 remote-as 65002 neighbor pg2 update-source 10.20.30.50 neighbor pg2 next-hop-self neighbor pg2 password $9$QxCvD7N6a0P96eT3BvnQfQ== neighbor pg2 remove-private-as neighbor pg2 bfd neighbor pg2 bfd interval 100 min-rx 300 multiplier 5 neighbor 10.20.20.5 remote-as 4200000000 neighbor 10.20.20.5 next-hop-self address-family ipv4 unicast network 172.31.254.214/32 network 172.31.254.246/32 neighbor pg2 prefix-list ipPrefixList2 in neighbor pg2 prefix-list ipPrefixList2 out neighbor pg2 route-map in routeMap2 neighbor pg2 route-map out routeMap2 neighbor pg1 prefix-list ipPrefixList1 in neighbor pg1 prefix-list ipPrefixList1 out neighbor pg1 route-map in routeMap1 neighbor pg1 route-map out routeMap1 neighbor pg1 send-community extended maximum-paths 8 graceful-restart ! address-family ipv6 unicast neighbor pg2 prefix-list ipPrefixList2 in neighbor pg2 prefix-list ipPrefixList2 out neighbor pg2 route-map in routeMap2 neighbor pg2 route-map out routeMap2 neighbor pg2 send-community both neighbor pg1 prefix-list ipPrefixList1 in neighbor pg1 prefix-list ipPrefixList1 out neighbor pg1 route-map in routeMap1 neighbor pg1 route-map out routeMap1 ! address-family l2vpn evpn graceful-restart ! ! |
