The following table describes the various attributes of standard and extended community list for which DRC and idempotency is supported. A drift is identified if any of the fields below are modified by user through SLX CLI or other management tools. Reconcile operation pushes the intended configuration to SLX, so bringing the SLX configuration in sync with EFA.
If you create an entry for idempotency which already exists in EFA, the system shows an error message stating that entry already exists.
| Field | Identify Drift | Reconcile config | Idempotency | Comments |
| community-list rule is deleted | Yes | Yes | No | Deleted rule will be reconciled. |
| community-list is deleted | Yes | Yes | No | Deleted community-list along with all rules associated with it will be reconciled. |
| community-list rule is changed | Yes | Yes | No | Updated rule will be reconciled. |
| community-list rule created by OOB. Different rules exist with same community-list name in EFA | No | No | NA | |
| Create a community-list OOB with a community-list name not matching any of EFA created entries | No | No | NA | These are treated as out of band entries and EFA will not perform DRC |
| extcommunity-list rule is deleted | Yes | Yes | No | Deleted rule will be reconciled. |
| extcommunity-list is deleted | Yes | Yes | No | Deleted community-list along with all rules associated with it will be reconciled. |
| extcommunity-list rule is changed | Yes | Yes | No | Updated rule will be reconciled. |
| extcommunity-list rule created by OOB. Different rules exist with same extcommunity-list name in EFA | No | No | NA | |
| Create an extcommunity-list OOB with a extcommunity-list name not matching any of EFA created entries | No | No | NA | These are treated as out of band entries and EFA will not perform DRC |
