The following table describes the various attributes of route map match and set for which DRC and idempotency is supported. A drift is identified if any of the fields mentioned in the following table are modified by user through SLX CLI or other management tools. Reconcile operation pushes the intended configuration to SLX, so bringing the SLX configuration in sync with EFA.
| Field | Identify Drift | Reconcile config | Idempotency | Comments |
| Update community-list name in match criteria | Yes | Yes | No | Reconcile the community-list name |
| Community-list match criteria deleted | Yes | Yes | NA | Reconcile the match criteria for community-list |
| Update extcommunity-list name in match criteria | Yes | Yes | No | Reconcile the extcommunity-list name |
| Extcommunity-list match criteria deleted | Yes | Yes | NA | Reconcile the match criteria for extcommunity-list |
| Update community-list name in set criteria | Yes | Yes | No | Reconcile the community-list name |
| Community-list set criteria deleted | Yes | Yes | NA | Reconcile the set criteria for community-list |
| Update community attribute in set criteria | Yes | Yes | No | Reconcile the community attribute |
| Community attribute set criteria deleted | Yes | Yes | NA | Reconcile the set criteria for community attribute |
| Update extcommunity rt attribute in set criteria | Yes | Yes | No | Reconcile the extcommunity rt attribute |
| Extcommunity rt attribute set criteria deleted | Yes | Yes | NA | Reconcile the set criteria for extcommunity rt attribute |
| Update extcommunity soo attribute in set criteria | Yes | Yes | No | Reconcile the extcommunity soo attribute |
| Extcommunity soo attribute set criteria deleted | Yes | Yes | NA | Reconcile the set criteria for extcommunity soo attribute |
| A different match criteria NOT supported by EFA is added through OOB | No | No | NA | These are treated as out of band entries and EFA will not store them |
| A different set criteria NOT supported by EFA is added through OOB | No | No | NA | These are treated as out of band entries and EFA will not store them |
| Route-map match criteria is created through OOB and this is not present/created by EFA | No | No | NA | These are treated as out of band entries and EFA will not perform DRC |
| Route-map set criteria is created through OOB and this is not present/created by EFA | No | No | NA | These are treated as out of band entries and EFA will not perform DRC |
