Configure Standard Community List
- Ensure that the community list name begins with an alphabet followed by one or more alphanumeric characters.
- Ensure that the community list rule is inside single or double quotes.
- If the community list is not associated with a device, the created community rules are stored in EFA DB only. If the community list is already associated with a device, the created rules are also pushed to the devices in addition to stored in DB.
Run the following command to
create a standard community list.
efa policy community-list create [flags] Flags: --name string Name of the community list. --type string Type of the community list. Valid options are standard, extended --rule stringArray Rule in format seq[seq-num],action[permit/deny],std-value[<1-4294967295>|<AA:NN, AA & NN is 2 bytes>|internet|local-as|no-export|no-advertise] (or) ext-value[regular expression]. Example: "seq[5],action[permit],std-value[6550:125;local-as;internet]" (or) "seq[4],action[deny],ext-value[^65000:.*_]"
Example:efa policy community-list create –-name comm1 –-type standard –-rule "seq[5],action[permit],std-value[100;11:22;local-as;no-export]" +-----------+-----+--------+--------------------+-------+ | Community | Seq | Action | Std Value | Ext | | List Name | num | | | Value | +-----------+-----+--------+--------------------+-------+ | comm-prye | 55 | permit | 100 11:22 | | | | | | local-as no-export | | +-----------+-----+--------+--------------------+-------+ Community List details +------------+--------+--------+-----------------+ | IP Address | Result | Reason | Rollback reason | +------------+--------+--------+-----------------+ Device Results efa policy community-list create –-name stdext1 –-type extended –-rule "seq[5],action[permit],ext-value[_2000_]" +---------------------+---------+--------+-----------+-----------+ | Community List Name | Seq num | Action | Std Value | Ext Value | +---------------------+---------+--------+-----------+-----------+ | stdext1 | 5 | permit | | _2000_ | +---------------------+---------+--------+-----------+-----------+ Community List details +------------+--------+--------+-----------------+ | IP Address | Result | Reason | Rollback reason | +------------+--------+--------+-----------------+ Device Results
Run the following command to update a community list.
efa policy community-list update [flags] Flags: --name string Name of the community list. --type string Type of the community list. Valid options are standard, extended --rule string Rule in format seq[seq-num],action[permit/deny],std-value[<1-4294967295>|<AA:NN, AA & NN is 2 bytes>|internet|local-as|no-export|no-advertise] (or) ext-value[regular expression]. Example: seq[5],action[permit],std-value[6550:125;local-as;internet] (or) seq[4],action[deny],ext-value[^65000:.*_] --operation string Valid options are update-rule, add-device, remove-device --ip string Comma separated range of device IP addresses. Example: "1.1.1.1-3","1.1.1.2","2.2.2.2"
Example:- Add
Device
efa policy community-list update --name stdext1 --type extended --operation add-device --ip 10.20.246.29-30 +---------------------+---------+--------+-----------+-----------+ | Community List Name | Seq num | Action | Std Value | Ext Value | +---------------------+---------+--------+-----------+-----------+ | stdext1 | 4 | deny | | _1000_ | +---------------------+---------+--------+-----------+-----------+ | stdext1 | 5 | permit | | _2000_ | +---------------------+---------+--------+-----------+-----------+ | stdext1 | 7 | deny | | _3000_ | +---------------------+---------+--------+-----------+-----------+ Community List details +--------------+---------+--------+-----------------+ | IP Address | Result | Reason | Rollback reason | +--------------+---------+--------+-----------------+ | 10.20.246.29 | Success | | | +--------------+---------+--------+-----------------+ | 10.20.246.30 | Success | | | +--------------+---------+--------+-----------------+ Device Results show running-config ip community-list ip community-list extended stdext1 seq 4 deny _1000_ ip community-list extended stdext1 seq 5 permit _2000_ ip community-list extended stdext1 seq 7 deny _3000_
Verify the switch configuration on SLX devices.SLX# show running-config ip community-list ip community-list standard comm1 seq 5 permit 0:100 11:22 local-as no-export ip community-list extended commExt1 seq 3 permit _30000_
- Delete
Device
efa policy community-list update --name comm1 --type standard --operation remove-device --ip 10.20.63.140-141 +---------------------+---------+--------+-----------+-----------+ | Community List Name | Seq num | Action | Std Value | Ext Value | +---------------------+---------+--------+-----------+-----------+ | comm1 | 3 | permit | 65:12 | | +---------------------+---------+--------+-----------+-----------+ Community List details +--------------+---------+--------+-----------------+ | IP Address | Result | Reason | Rollback reason | +--------------+---------+--------+-----------------+ | 10.20.63.140 | Success | | | +--------------+---------+--------+-----------------+ | 10.20.63.141 | Success | | | +--------------+---------+--------+-----------------+ Device Results
- Update
rule
efa policy community-list update --name commExt1 --type extended --operation update-rule --rule "seq[1],action[permit],ext-value[_30000_]" +---------------------+---------+--------+ | Community List Name | Seq num | Action | +---------------------+---------+--------+ | commExt1 | 1 | permit | +---------------------+---------+--------+ Community List details +---------------+----------+---------------------------------------+----------+ | IP Address | Result | Reason | Rollback | | | | | reason | +---------------+----------+---------------------------------------+----------+ | 10.139.44.159 | Success | | | +---------------+----------+---------------------------------------+----------+ | 10.139.44.163 | Success | | | +---------------+----------+---------------------------------------+----------+ Device Results On 10.139.44.159: show running-config ip community-list ip community-list extended commExt1 seq 30 action permit _30000_ efa policy community-list update –-name comm1 –-type standard –-operation update-rule "–-rule seq[5]","action[permit]","std-value[100;no-advertise]" +---------------+---------+--------------------------------------------+----------+ | IP Address | Result | Reason | Rollback | | | | | reason | +---------------+---------+--------------------------------------------+----------| | 10.139.44.159 | Failed | Failed to create community list for | | | | | comm1 on the device 10.139.44.159. | | | | | Reason: For seq 5: netconf rpc [error] | | | | | '%Error: Same filter is already configured | | | | | with sequencenumber 30.' | | +---------------+---------+--------------------------------------------+----------+ | 10.139.44.163 | Rollback| | | +---------------+---------+--------------------------------------------+----------+ Device Results On 10.139.44.159: show running-config ip community-list ip community-list standard comm1 seq 30 action permit 100 no-advertise
- Add
Device
Run the following command to delete a community list.
efa policy community-list delete [flags] Flags: --name string Name of the community list. --type string Type of the community list. Valid options are standard, extended. --seq string Sequence numbers. For example 5,10,20 or all
- The CLI deletes the standard community list rules on all devices for the name, type, and sequence number provided and then deletes the community list rules from EFA.
- Pre-validation is done for seq IDs provided or for all sequence ids in case of 'all'. If any out-of-band, seq ID is provided in the request (or 'all' is specified and any out-of-band seq ID exists), the operation is errored out without proceeding to remove config from device or EFA DB.
- You must either provide only EFA managed seq IDs in the CLI or REST request or remove the out-of-band seq IDs from device and execute the CLI or REST request again.
Example:efa policy community-list delete --name commExt1 --seq all --type standard +---------------------+---------+--------+ | Community List Name | Seq num | Action | +---------------------+---------+--------+ | commExt1 | 1 | permit | +---------------------+---------+--------+ | commExt1 | 2 | permit | +---------------------+---------+--------+ | commExt1 | 3 | permit | +---------------------+---------+--------+ Community List details +---------------+---------+--------------+----------+ | IP Address | Result | Reason | Rollback | | | | | reason | +---------------+---------+--------------+----------+ | 10.139.44.159 | Success | | | +---------------+---------+--------------+----------+ | 10.139.44.163 | Success | | | +---------------+---------+--------------+----------+ Device Results
Run the following command to show a community list.
efa policy community-list list [flags] Flags: --ip string Comma separated range of device IP addresses. Example: 1.1.1.1-3,1.1.1.2,2.2.2.2 --name string Name of the community list. --type string Type of the community list. Valid options are standard, extended
Example,efa policy community-list list Community list details: Name: clist1 Seq: 5 Action: deny StdValue: 50:125 internet local-as no-advertise ExtValue: Name: clist1 Seq: 15 Action: deny StdValue: 50:125 local-as ExtValue: Name: clist2 Seq: 1 Action: permit StdValue: ExtValue: _2000_ efa policy community-list list –-type standard –-ip 10.20.246.29-30 Community list details: Name: clist1 Seq: 5 Action: deny StdValue: 50:125 internet local-as no-advertise ExtValue: Name: clist1 Seq: 15 Action: deny StdValue: 50:125 local-as ExtValue: IP Addresses: +--------+-----+--------------+-------------+ | Name | Seq | IP Address | App State | +--------+-----+--------------+-------------+ | clist1 | 5 | 10.20.246.29 | cfg-in-sync | +--------+-----+--------------+-------------+ | clist1 | 5 | 10.20.246.30 | cfg-in-sync | +--------+-----+--------------+-------------+ | clist1 | 15 | 10.20.246.29 | cfg-in-sync | +--------+-----+--------------+-------------+ | clist1 | 15 | 10.20.246.30 | cfg-in-sync | +--------+-----+--------------+-------------+
