Importing a Fabric Database
You can import the fabric databases
(including devices) of EFA versions that are earlier than version 2.1.0. The support of an
older database by newer software is often called Brownfield support.
EFA supports the import (or migration) fabric databases of earlier versions in the following
ways:
- You can import devices that were
configured in the fabric of the earlier version of EFA.
- You can import the fabric that
was configured in the earlier version of EFA.
- You can import and configure the
fabric and the devices using the efa fabric import
and efa fabric
configure commands.
- You can import only 3-stage Clos
fabrics because only 3-stage Clos fabrics were supported in earlier versions of
EFA (pre-2.1.0).
When you run the
efa fabric import command, EFA performs the following
tasks:
- Learns (fetches) the device configuration and registers the devices with the EFA
Inventory service. If registration fails for any device, EFA removes all devices
from the inventory. You must fix the errors and rerun the command.
- Fetches the older fabric settings and creates
a new fabric. You provide the new fabric name when you run the command. If the
fabric name you provide already exists, with devices added to it, then an error
is returned. You must fix the error and then rerun the command.
- Adds the registered devices to the new fabric
and validates the configurations for global devices, interfaces, MCT, overlay
gateway, EVPN, and BGP. For any conflict in the configuration, EFA deletes the
devices from the fabric, unregisters the devices, and deletes the new fabric.
The devices retain their pre-import configuration. You must fix the
configuration conflicts and then rerun the command.
The following configuration
deviations are allowed: the MCT cluster name, the EVPN name, the overlay
gateway name, and the MCT cluster node ID. In each case, the value is taken
from the device.
Upon successful migration, devices that are added to the fabric have the provisioning state of
CFG-READY. You then
run the efa fabric
configure command to transition the devices to the CFG-IN-SYNC state.
For more information, see Considerations for Importing a Fabric Database.
