Clos Fabric with Auto VNI Map
- In Clos fabric with auto VNI map,
the VNI is statically derived using the VLAN ID or BD ID.
- For the VLAN case, VNI = VLAN ID
- For the BD case, VNI = 4096 + BD ID
- You cannot reserve l2-vni-range or l3-vni-range for a given tenant.
- You cannot provide a specific l2-vni or l3-vni in an endpoint group.
- VLAN Based Tenants:
Multiple VLAN based tenants cannot share the same VLAN, considering the multiple tenants cannot share the same VNI.
- BD Based Tenants:
Multiple BD based tenants can share the same VLAN, as the VLANs from each tenant are mapped to a unique BD and further a unique VNI.
Multi Tenancy
EFA supports multi tenancy by allowing multiple tenants to have overlapping ctags and non-overlapping L2VNI. A tenant ctag will get a unique L2VNI and a unique network allocated in the fabric
The following example shows a multi tenancy configuration.
efa tenant create --name tenant11 --vrf-count 10 --vlan-range 2-4090 --port 10.24.80.134[0/15-17],10.24.80.135[0/15-17],10.25.225.11[0/15-17],10.25.225.46[0/15-17],10.24.85.74[0/15-17],10.24.85.76[0/15-17] --description Subscriber1 efa tenant show +----------+-------------+-------------+------------+-----------+-----------+-----------------------+ | Name | L2VNI-Range | L3VNI-Range | VLAN-Range | VRF-Count | Enable-BD | Ports | +----------+-------------+-------------+------------+-----------+-----------+-----------------------+ | tenant11 | | | 2-4090 | 10 | False | 10.24.85.74[0/15-17] | | | | | | | | 10.24.80.135[0/15-17] | | | | | | | | 10.25.225.11[0/15-17] | | | | | | | | 10.25.225.46[0/15-17] | | | | | | | | 10.24.80.134[0/15-17] | | | | | | | | 10.24.85.76[0/15-17] | +----------+-------------+-------------+------------+-----------+-----------+-----------------------+ efa tenant create --name tenant12 --vrf-count 10 --vlan-range 2-4090 --port 10.24.80.134[0/18-20],10.24.80.135[0/18-20],10.25.225.11[0/18-20],10.25.225.46[0/18-20],10.24.85.74[0/18-20],10.24.85.76[0/18-20] Tenant Creation Failed: Vlan (2) overlaps with Tenant (tenant11) efa tenant create --name tenant21 --vrf-count 10 --enable-bd --port 10.24.80.134[0/21-25],10.24.80.135[0/21-25],10.24.85.74[0/21-25],10.24.85.76[0/21-25],10.25.225.11[0/21-25],10.25.225.46[0/21-25] efa tenant create --name tenant22 --vrf-count 10 --enable-bd --port 10.24.80.134[0/26-30],10.24.80.135[0/26-30],10.24.85.74[0/26-30],10.24.85.76[0/26-30],10.25.225.11[0/26-30],10.25.225.46[0/26-30] efa tenant show +----------+-------------+-------------+------------+-----------+-----------+-----------------------+ | Name | L2VNI-Range | L3VNI-Range | VLAN-Range | VRF-Count | Enable-BD | Ports | +----------+-------------+-------------+------------+-----------+-----------+-----------------------+ | tenant11 | | | 2-4090 | 10 | False | 10.25.225.46[0/15-17] | | | | | | | | 10.25.225.11[0/15-17] | | | | | | | | 10.24.80.135[0/15-17] | | | | | | | | 10.24.85.74[0/15-17] | | | | | | | | 10.24.85.76[0/15-17] | | | | | | | | 10.24.80.134[0/15-17] | +----------+-------------+-------------+------------+-----------+-----------+-----------------------+ | tenant21 | | | 2-4090 | 10 | True | 10.24.85.74[0/21-25] | | | | | | | | 10.25.225.11[0/21-25] | | | | | | | | 10.25.225.46[0/21-25] | | | | | | | | 10.24.80.134[0/21-25] | | | | | | | | 10.24.85.76[0/21-25] | | | | | | | | 10.24.80.135[0/21-25] | +----------+-------------+-------------+------------+-----------+-----------+-----------------------+ | tenant22 | | | 2-4090 | 10 | True | 10.24.85.76[0/26-30] | | | | | | | | 10.25.225.11[0/26-30] | | | | | | | | 10.24.80.135[0/26-30] | | | | | | | | 10.25.225.46[0/26-30] | | | | | | | | 10.24.85.74[0/26-30] | | | | | | | | 10.24.80.134[0/26-30] | +----------+-------------+-------------+------------+-----------+-----------+-----------------------+ efa tenant epg create --name epg11 --tenant tenant11 --po po1115,po1215,po1315 --switchport-mode trunk --switchport-native-vlan 11 --ctag-range 11-12 efa tenant epg create --name epg21 --tenant tenant21 --po po2121,po2221,po2321 --switchport-mode trunk --ctag-range 11-12 efa tenant epg create --name epg22 --tenant tenant21 --po po2122,po2222,po2322 --switchport-mode trunk --ctag-range 11-12 efa tenant epg show ====================================================================== Name : epg11 Tenant : tenant11 Description : Ports : POs : po1315, po1215, po1115 Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy : ctag-range : 11-12 Network Property [Flags : * - Native Vlan] +------+--------+------------+---------+-------------+-------------+ | Ctag | L2-Vni | Anycast-ip | BD-name | Dev-state | App-state | +------+--------+------------+---------+-------------+-------------+ | 11* | 11 | | | provisioned | cfg-in-sync | +------+--------+------------+---------+-------------+-------------+ | 12 | 12 | | | provisioned | cfg-in-sync | +------+--------+------------+---------+-------------+-------------+ ====================================================================== ====================================================================== Name : epg21 Tenant : tenant21 Description : Ports : POs : po2121, po2221, po2321 Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy : ctag-range : 11-12 Network Property [Flags : * - Native Vlan] +------+--------+------------+--------------+-------------+-------------+ | Ctag | L2-Vni | Anycast-ip | BD-name | Dev-state | App-state | +------+--------+------------+--------------+-------------+-------------+ | 11 | 4099 | | Auto-BD-4099 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ | 12 | 4100 | | Auto-BD-4100 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ ====================================================================== ====================================================================== Name : epg22 Tenant : tenant21 Description : Ports : POs : po2122, po2222, po2322 Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy : ctag-range : 11-12 Network Property [Flags : * - Native Vlan] +------+--------+------------+--------------+-------------+-------------+ | Ctag | L2-Vni | Anycast-ip | BD-name | Dev-state | App-state | +------+--------+------------+--------------+-------------+-------------+ | 12 | 4102 | | Auto-BD-4102 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ | 11 | 4101 | | Auto-BD-4101 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ efa tenant epg create --name epg23 --tenant tenant21 --po po2122,po2322 --switchport-mode trunk --ctag-range 21-22 --bridge-domain 21:Auto-BD-4101 --bridge-domain 22:Auto-BD-4102 efa tenant epg show ====================================================================== Name : epg11 Tenant : tenant11 Description : Ports : POs : po1315, po1215, po1115 Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy : ctag-range : 11-12 Network Property [Flags : * - Native Vlan] +------+--------+------------+---------+-------------+-------------+ | Ctag | L2-Vni | Anycast-ip | BD-name | Dev-state | App-state | +------+--------+------------+---------+-------------+-------------+ | 11* | 11 | | | provisioned | cfg-in-sync | +------+--------+------------+---------+-------------+-------------+ | 12 | 12 | | | provisioned | cfg-in-sync | +------+--------+------------+---------+-------------+-------------+ ====================================================================== ====================================================================== Name : epg21 Tenant : tenant21 Description : Ports : POs : po2121, po2221, po2321 Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy : ctag-range : 11-12 Network Property [Flags : * - Native Vlan] +------+--------+------------+--------------+-------------+-------------+ | Ctag | L2-Vni | Anycast-ip | BD-name | Dev-state | App-state | +------+--------+------------+--------------+-------------+-------------+ | 11 | 4099 | | Auto-BD-4099 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ | 12 | 4100 | | Auto-BD-4100 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ ====================================================================== ====================================================================== Name : epg22 Tenant : tenant21 Description : Ports : POs : po2122, po2222, po2322 Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy : ctag-range : 11-12 Network Property [Flags : * - Native Vlan] +------+--------+------------+--------------+-------------+-------------+ | Ctag | L2-Vni | Anycast-ip | BD-name | Dev-state | App-state | +------+--------+------------+--------------+-------------+-------------+ | 12 | 4102 | | Auto-BD-4102 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ | 11 | 4101 | | Auto-BD-4101 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ ====================================================================== ====================================================================== Name : epg23 Tenant : tenant21 Description : Ports : POs : Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy : ctag-range : 21-22 Network Property [Flags : * - Native Vlan] +------+--------+------------+--------------+-------------+-------------+ | Ctag | L2-Vni | Anycast-ip | BD-name | Dev-state | App-state | +------+--------+------------+--------------+-------------+-------------+ | 21 | 4101 | | Auto-BD-4101 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ | 22 | 4102 | | Auto-BD-4102 | provisioned | cfg-in-sync | +------+--------+------------+--------------+-------------+-------------+ ======================================================================
