| Scenario | 2.3.2 Target Device List | 2.4.0 Target Device List | EFA 2.3.2 Resultant Topology | EFA 2.4.0 and above Resultant Topology |
| Single Homed PO Create with PO member on Rack1Device2 | Rack1Device2 | Rack1Device1 Rack1Device2 | Complete Failure | Partial Success |
| Endpoint group (EPG) create with cluster edge port (CEP) member on Rack1Device2 | Rack1Device2 Rack1Device1 |
Rack1Device1 Rack1Device2 | Partial Success | Partial Success |
| BGP Peer Group create with the peer-group residing on Rack1Device2 | Rack1Device2 | Rack1Device1 Rack1Device2 | Complete Failure | Partial Success |
| BGP Peer Create with the static or dynamic BGP peers residing on Rack1Device2 | Rack1Device2 | Rack1Device1 Rack1Device2 | Complete Failure | Partial Success |
| VRF update with SR or SR-BFD residing on Rack1Device2 | Rack1Device2 | Rack1Device1 Rack1Device2 | Complete Failure | Partial Success |
efa tenant show +------+-------------+-------------+------------+-----------+-----------+---------+----------------------+ | Name | L2VNI-Range | L3VNI-Range | VLAN-Range | VRF-Count | Enable-BD | Type | Ports | +------+-------------+-------------+------------+-----------+-----------+---------+----------------------+ | ten1 | | | 11-20 | 10 | False | private | 10.20.246.15[0/1-10] | | | | | | | | | 10.20.246.16[0/1-10] | +------+-------------+-------------+------------+-----------+-----------+---------+----------------------+ Tenant Details efa inventory admin-state down --ip 10.20.246.15 AdminStateDown [success] Admin State Down execution UUID: 6eaa1ebe-40fe-4628-8d5c-df11ffc4521e execute the CLI to get details : efa inventory admin-state detail --uuid 6eaa1ebe-40fe-4628-8d5c-df11ffc4521e efa inventory admin-state detail --uuid 6eaa1ebe-40fe-4628-8d5c-df11ffc4521e +--------------------------------+--------------------------------------+ | NAME | VALUE | +--------------------------------+--------------------------------------+ | UUID | 6eaa1ebe-40fe-4628-8d5c-df11ffc4521e | +--------------------------------+--------------------------------------+ | Device IP | 10.20.246.15 | +--------------------------------+--------------------------------------+ | Admin State Action | down | +--------------------------------+--------------------------------------+ | Status | success | +--------------------------------+--------------------------------------+ | Fabric Status | success | +--------------------------------+--------------------------------------+ | Tenant Status | success | +--------------------------------+--------------------------------------+ | Maintenance Mode Enable Status | success | +--------------------------------+--------------------------------------+ | Start Time | 2021-02-06 21:18:53 -0800 PST | +--------------------------------+--------------------------------------+ | Last Modified | 2021-02-06 21:19:59 -0800 PST | +--------------------------------+--------------------------------------+ | Duration | 1m5.517263907s | +--------------------------------+--------------------------------------+
efa tenant po create --name ten1po1 --tenant ten1 --port 10.20.246.15[0/1-2] --speed 10Gbps --negotiation active PortChannel creation failed: Error: Device 10.20.246.15 is administratively down efa tenant po create --name ten1po1 --tenant ten1 --port 10.20.246.16[0/1-2] --speed 10Gbps --negotiation active PortChannel created successfully. efa tenant epg create --name ten1epg1 --tenant ten1 --po ten1po1 --switchport-mode trunk --ctag-range 11-12 --anycast-ip 11:10.0.11.1/24 --anycast-ip 12:10.0.12.1/24 --vrf ten1vrf1 --l2-vni 11:11 --l2-vni 12:12 --l3-vni 8192 EndpointGroup created successfully. efa tenant service bgp peer create --name ten1bgppeer1 --tenant ten1 --ipv4-uc-nbr 10.20.246.15,ten1vrf1:10.0.0.0,65001 BgpService creation Failed: Error: Devices [10.20.246.15] are administratively down efa tenant service bgp peer-group create --name ten1bgppeergroup1 --tenant ten1 --pg-name 10.20.246.15:pg1 --pg-asn 10.20.246.15,pg1:65010 BgpService creation Failed: Error: Devices [10.20.246.15] are administratively down
efa tenant po show --name ten1po1 --tenant ten1
| Name | Tenant | ID | Speed | Negotiation | Min Link | Lacp | Ports | State | Dev State | App State |
| | | | | | Count | Timeout | | | | |
| ten1po1 | ten1 | 1 | 10Gbps | active | 1 | long | 10.20.246.15[0/1-2] | po-created | not-provisioned | cfg-ready |
efa tenant vrf show --name ten1vrf1 --tenant ten1
(efa:root)root@node-2:~# efa tenant vrf show --name ten1vrf1 --tenant ten1
| Name | Tenant | Routing Type | Centralized Routers | Redistribute | Max Path | Local Asn | Enable GR | State | Dev State | App State |
| ten1vrf1 | ten1 | distributed | | connected,static | 50 | 65002 | false | vrf-create | not-provisioned | cfg-ready |
efa tenant epg show --detail
Tenant : ten1
Description :
Type : extension
Ports :
POs :
: unstable : ten1po1
Port Property : switchport mode : trunk
: native-vlan-tagging : false
NW Policy : ctag-range : 11-12
: vrf : ten1vrf1 [unstable]
: l3-vni : 8192
Network Property [Flags : * - Native Vlan]
| Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) | Ctag-Description | Mtu-IPv6-ND | ManagedConfig-IPv6-ND | OtherConfig-IPv6-ND | Dev-state | App-state |
| 11 | 11 | 10.0.11.1/24 | | | | Tenant L3 Extended VLAN | | False | False | not-provisioned | cfg-ready |
| 12 | 12 | 10.0.12.1/24 | | | | Tenant L3 Extended VLAN | | False | False | not-provisioned | cfg-ready |
efa tenant service bgp peer-group show
Tenant : ten1
State : bgp-pg-state-created
Description :
| Device IP | PEER-GROUP-NAME | REMOTE ASN | BFD Enabled | BFD Interval | BFD Rx | BFD Multiplier | Next-Hop-Self | Update-Source-IP | Dev-state | App-state |
| 10.20.246.15 | pg1 | 65010 | false | 0 | 0 | 0 | false | | not-provisioned | cfg-ready |
efa tenant service bgp peer show
Tenant : ten1
State : bs-state-created
Description :
Static Peer:
| Device IP | VRF | AFI | SAFI | REMOTE IP | REMOTE ASN | BFD Enabled | BFD Interval | BFD Rx | BFD Multiplier | Next Hop Self | Update Source IP | Dev-state | App-state |
| 10.20.246.15 | ten1vrf1 | ipv4 | unicast | 10.0.0.0 | 65001 | false | 0 | 0 | 0 | false | | not-provisioned | cfg-ready |
Dynamic Peer:
| Device IP | VRF | AFI | SAFI | Listen Range | Peer Group | Listen Limit | Dev-state | App-state |
efa inventory admin-state up --ip 10.20.246.15
AdminStateUp [success]
Admin State Up started execution UUID: 0ae0db00-c0de-4d55-8410-6d67bca4ad65
efa inventory admin-state detail --uuid 0ae0db00-c0de-4d55-8410-6d67bca4ad65
| NAME | VALUE |
| UUID | 0ae0db00-c0de-4d55-8410-6d67bca4ad65 |
| Admin State Action | up |
| Status | success |
| Drift and Reconcile id | a3c987ea-f709-4f7c-8ae4-bc5c9481cc55 |
| Drift and Reconcile Status | DR Completed |
| Start Time | 2021-02-06 21:39:09 -0800 PST |
| Last Modified | 2021-02-06 21:47:09 -0800 PST |
| Duration | 8m0.126957723s |
--- Time Elapsed: 47.334754ms ---
| ten1vrf1 | ten1 | distributed | | connected,static | 50 | 65002 | false | vrf-device-created | provisioned | cfg-in-sync |
efa tenant po show
| Name | Tenant | ID | Description | Speed | Negotiation | MinLinkCount | Ports | LacpTimeout | State | Dev-State | App-State |
| ten1po1 | ten1 | 1 | EFA Port-channel ten1po1 | 10Gbps | active | 1 | 10.20.246.15[0/1-2] | long | po-created | provisioned | cfg-in-sync |
efa tenant epg show
Tenant : ten1
Description :
Type : extension
Ports :
POs :
: vrf : ten1vrf1
: l3-vni : 8192
| 11 | 11 | 10.0.11.1/24 | | | | Tenant L3 Extended VLAN | | False | False | provisioned | cfg-in-sync |
| 12 | 12 | 10.0.12.1/24 | | | | Tenant L3 Extended VLAN | | False | False | provisioned | cfg-in-sync |
For 'unstable' entities, run 'efa tenant po/vrf show' for details
Tenant : ten1
Description :
| 10.20.246.15 | pg1 | 65010 | false | 0 | 0 | 0 | false | | provisioned | cfg-in-sync |
Tenant : ten1
Description :
Static Peer:
| 10.20.246.15 | ten1vrf1 | ipv4 | unicast | 10.0.0.0 | 65001 | false | 0 | 0 | 0 | false | | provisioned | cfg-in-sync |
Dynamic Peer:
