Configure an IP Multicast Fabric
Tip
If any devices in a fabric are in "admin-down" state, use of the following commands in that same fabric will not add or delete devices in the fabric: efa fabric device add-bulk and efa fabric device remove.Procedure
Create a Clos fabric.
# efa fabric create –-name clos_fabric --type clos --stage 3
Optimized replication is not supported on small data center fabric. -
Enable multicast fabric
settings.
# efa fabric setting update –-optimized-replication-enable yes –-name clos_fabric
- Optional:
Override the default MDT group
and group range.
# efa fabric setting update –-name clos_fabric –-mdtgroup-range <A.B.C.D/L> –-default-mdtgroup <A.B.C.D> # efa fabric setting update –-name clos_fabric –-mdtgroup-range 239.0.0.0/8 –-default-mdtgroup 239.1.1.1
Verify the fabric
settings.
# efa fabric setting show --name clos_fabric --advanced +--------------------------------+------------------------+ | Optimized Replication Enable | Yes | +--------------------------------+------------------------+ | MDT Group IPv4 Range | 238.0.0.0/8 | +--------------------------------+------------------------+ | Default MDT Group IPv4 address | 238.1.1.1 | +--------------------------------+------------------------+
Add devices to the fabric.
# efa fabric device add-bulk --name clos_fabric --leaf Leaf1IP,Leaf2IP,Leaf3IP,Leaf4IP --spine Spine1IP,Spine2IP --username admin --password password
Configure the fabric.
# efa fabric configure –name clos_fabric
Verify the fabric
configuration.
# efa fabric show-config --name clos_fabric --advanced
- All underlay configuration and overlay configurations are pushed to the devices and underlay topology is operational.
- All BGP connections between leaf and spine nodes are established and neighbors are reachable.
- Basic overlay configuration with optimized replication is configured.
- All device configurations are applied to the devices in fabric. For more information, see Device Configuration.
Create a tenant and endpoint
group to bring up the multicast tunnels with leaf nodes.
# efa tenant create --name tenant1 --l2-vni-range 10002-14190 --l3-vni-range 14191-14200 --vrf-count 10 --vlan-range 2-4090 --port Leaf1IP[0/12-16],Leaf2IP[0/12-16], Leaf3IP[0/12-16],Leaf4IP[0/12-16] --description Subscriber1 # efa tenant epg create --name epg1 --tenant tenant1 --port Leaf1IP[0/15],Leaf2IP[0/15],Leaf3IP[0/16 --switchport-mode trunk --ctag-range 100
