Use the EFA CLI to add and delete management subinterfaces.
efa mgmt subinterface create [ --name sub | --vlan-id vlan-id | --ip-addr ip-addr --ipv6-address ipv6-addr ]
#efa mgmt subinterface show +------+-----------------+------+---------------+-------------+ | Name | Parent Interface| Vlan | IP Subnet | IPv6 Subnet | +------+-----------------+------+---------------+-------------| | sub1 | ens160 | 100 | 10.10.10.1/24 | | +------+-----------------+------+---------------+-------------+ | sub2 | ens160 | 200 | 11.11.11.1/24 | 2000::1/64 | +------+-----------------+------+---------------+-------------+ | sub3 | ens160 | 300 | 13.13.13.1/24 | | +------+-----------------+------+---------------+-------------+ | sub4 | ens160 | 400 | 14.14.14.1/24 | 3000::1/64 | +------+-----------------+------+---------------+-------------+
efa mgmt subinterface delete --name <name>
$ efa mgmt subinterface? Management subinterface commands Usage: efa mgmt subinterface [command] Available Commands: create Create sub-interface (sub-interface) delete Delete sub-interface (sub-interface) show List of sub-interfaces (sub-interfaces) Use "efa mgmt subinterface [command] --help" for more information about a command.
$ efa mgmt subinterface create -h
Create management subinterface (sub-interface)
Usage:
efa mgmt subinterface create [flags]
Flags:
--name string Name of the sub-interface
--vlan-id int VLAN Id of sub-interface
--ip-address string IP Address of sub-interface including subnet mask.
$ efa subinterface delete -h
Delete management subinterface (sub-interface)
Usage:
efa mgmt subinterface delete [flags]
Flags:
$ efa mgmt subinterface show -h
List of management sub-interfaces (sub-interfaces)
Usage:
efa mgmt subinterface show [flags]
Flags:
$ efa mgmt subinterface create --name server1 --vlan-id 20 --ip-address
20.20.20.2/24
Subinterface server1 created successfully
$ efa mgmt subinterface delete --name server1 Subinterface server1 deleted successfully
$ efa mgmt subinterface show +------+------------------+------+-----------------+-------------+ | Name | Parent Interface | Vlan | IP Subnet | IPv6 Subnet | +------+------------------+------+-----------------+-------------+ | sub1 | ens160 | 100 | 10.10.10.1/24 | | +------+------------------+------+-----------------+-------------+ | sub2 | ens160 | 200 | 11.11.11.1/24 | 2000::1/64 | +------+------------------+------+-----------------+-------------+ | sub3 | ens160 | 300 | 13.13.13.1/24 | | +------+------------------+------+-----------------+-------------+ | sub4 | ens160 | 400 | 14.14.14.1/24 | 3000::1/64 | +------+------------------+------+-----------------+-------------+ Management Subinterfaces Details
$ efa mgmt subinterface show --name server1 +---------------+------------------+------+---------------+ | Sub-Interface | Parent Interface | Vlan | IP Subnet | +---------------+------------------+------+---------------+ | server1 | eth0 | 20 | 20.20.20.2/24 | +---------------+------------------+------+---------------+ Management Subinterface Details
