| Top Level Hierarchy | Description |
| System |
All the common software modules that make up the EFA infrastructure would come under this node. For example, Database, K3s, Services, HA, and Certificate. There can be more sub-nodes under this as deemed necessary. |
| Component | This node groups all components (features) that are provided by EFA. For example, Fabric, Visibility, Common, Tenant (can be used for grouping all common features like License and Security). This Component tree is extensible for adding new features and add-ons in EFA. All entities are represented as resources in EFA so that they become addressable. |
For example,
Representing managed objects (for example, Fabric, Tenant, EPG, Devices, Interfaces) and the software components (for example, License, Security, Fault) as Resource has the following advantages:
