Configure the SPB-PIM Gateway interface parameters on a brouter port.
Variable definitions
The following table defines parameters for the ip spb-pim-gw command.
Variable |
Value |
hello-interval<0-18724> |
Specifies the HELLO interval in seconds. The default value is 30 seconds. |
join-prune-interval<1-18724> |
Specifies the JOIN PRUNE interval in seconds. The default value is 60 seconds. |
