Perform this procedure to enable Energy Saver or EEE on one or more ports.
- On the Device Physical View tab, select one or more ports.
 - Select General.
 - Select the Energy Saver tab.
                Enable either Energy Saver or EEE:
To enable Energy Saver, select EnergySaverEnabled.
To enable EEE, select EnergySaverEEEEnable.
 - Select Apply.
Energy Saver Field Descriptions
Use the data in the following table to use the Energy Saver tab.
| Name | Description |
                                 Port  |
                                 Specifies the port number.  |
                                 EnergySaverEnabled  |
                                 Configures whether Energy Saver is enabled on the specific port.  |
                                 EnergySavedPoeStatus  |
                                 Specifies the Energy Saver PoE status for the specific port.  |
                                 EnergySaverEEEEnable  |
                                 Configures whether EEE is enabled on the specific port.  |
