Use the following procedure to configure the limit for data transmission during the session.
Switch:1>enable Switch:1#configure terminal
Configure the SSH rekey data-limit to 2 GB:
Switch:1(config)#ssh rekey data-limit 2
The following table defines parameters for the ssh rekey data-limit command.
Variable |
Value |
<1–6> |
Sets the SSH rekey data limit in GB, range is 1–6. |
