The following figure shows a sample IP Shortcuts over SPBM deployment.
Examples and network illustrations in this document may illustrate only one of the supported platforms. Unless otherwise noted, the concept illustrated applies to all supported platforms.
The following sections show the steps required to configure the SPBM IP Shortcuts parameters in this example. You must first configure basic SPBM and IS-IS infrastructure. For more information, see SPBM and IS-IS Infrastructure Configuration.
Note the following:
IP IS-IS redistribution needs to be configured to inject IP shortcuts routes into IS-IS. The one exception is the circuitless IP address configured as the IS-IS ip-source-address. This address is automatically advertised without the need for a redistribution rule.
In the displayed configuration, only direct routes are injected (the same configuration is possible for static routes). To inject IPv6 routes, you must enable route redistribution of IPv6 direct, IPv6 static, and OSPFv3 routes into IS-IS.
No IP address needs to be configured on SwitchG.
CIRCUITLESS INTERFACE CONFIGURATION - GlobalRouter interface loopback 1 ip address 1 10.0.0.1/255.255.255.255 exit ISIS CONFIGURATION router isis ip-source-address 10.0.0.1 ISIS SPBM CONFIGURATION spbm 1 ip enable exit VLAN CONFIGURATION vlan create 13 type port-mstprstp 0 vlan members 13 1/2 portmember interface Vlan 13 ip address 10.0.13.1 255.255.255.0 exit IP REDISTRIBUTION CONFIGURATION - GlobalRouter router isis redistribute direct redistribute direct metric 1 redistribute direct enable exit IP REDISTRIBUTE APPLY CONFIGURATIONS isis apply redistribute direct
CIRCUITLESS INTERFACE CONFIGURATION - GlobalRouter interface loopback 1 ip address 1 10.0.0.2/255.255.255.255 exit ISIS CONFIGURATION router isis ip-source-address 10.0.0.2 ISIS SPBM CONFIGURATION spbm 1 ip enable exit VLAN CONFIGURATION vlan create 14 type port-mstprstp 0 vlan member add 14 1/2 interface Vlan 14 ip address 10.0.14.1 255.255.255.0 exit IP REDISTRIBUTION CONFIGURATION - GlobalRouter router isis redistribute direct redistribute direct metric 1 redistribute direct enable exit IP REDISTRIBUTE APPLY CONFIGURATIONS isis apply redistribute direct
SwitchC:1# show isis spbm ip-unicast-fib
                         SPBM IP-UNICAST FIB ENTRY INFO
                                               OUTGOING   SPBM PREFIX  PREFIX   IP ROUTE
VRF   ISID    Destination    NH BEB    VLAN    INTERFACE  COST COST    TYPE     PREFERENCE  AREA  AREA-NAME
GRT    -      10.0.0.2/32    SwitchD     4000     1/30     20    1     Internal  7          HOME   area-9.00.02
GRT    -      10.0.14.1/24   SwitchD     4000     1/30     20    1     Internal  7          HOME   area-9.00.02
 Home : Total number of SPBM IP-UNICAST FIB entries 2
 Remote: Total number of SPBM IP-UNICAST FIB entries 0
SwitchC:1# show ip route
                            IP Route - GlobalRouter
                                                NH   INTER
DST         MASK           NEXT          VRF    COST  FACE	PROT AGE TYPE PRF
10.0.0.1   255.255.255.255  10.0.0.1      -       1     0 	 LOC	 0	  DB	 0
10.0.0.2   255.255.255.255  SwitchD      Glob~    20   4000  ISIS  0  IBS  7
10.0.13.1   255.255.255.0   10.0.13.1    -        1    13    LOC   0  DB   0
10.0.14.1   255.255.255.0   SwitchD      Glob~    20   4000  ISIS  0  IBS  7
4 out of 4 Total Num of Route Entries, 4 Total Num of Dest Networks displayed.
TYPE Legend:
I=Indirect Route, D=Direct Route, A=Alternative Route, B=Best Route, E=Ecmp Rout
e,
U=Unresolved Route, N=Not in HW, F=Replaced by FTN, V=IPVPN Route, S=SPBM Route
PROTOCOL Legend:
v=Inter-VRF route redistributed
 SwitchD:1# show isis spbm ip-unicast-fib
GRT     -       10.0.0.1/32    SwitchC     4000     1/20      20     1        Internal  7          HOME   area-9.00.02
GRT     -       10.0.13.1/24   SwitchC     4000     1/20      20     1        Internal  7          HOME   area-9.00.02
SwitchD:1# show ip route
                                                NH   INTER
10.0.0.1    255.255.255.255 SwitchC       Glob~  20   4000 ISIS 0   IBS  7
10.0.0.2    255.255.255.255 10.0.0.2      -      1    0    LOC  0   DB   0
10.0.13.1   255.255.255.0   SwitchC       Glob~  20   4000 ISIS 0   IBS  7
10.0.14.1   255.255.255.0   10.0.14.1     -      1    14   LOC  0   DB   0
TYPE Legend:
e,
PROTOCOL Legend:
