View a summary of BGP peering over IPv6 transport.
The following example shows partial output for the show bgp ipv6 summary command.
Switch:1>show bgp ipv6 summary vrf vrf1
BGP ipv6 Summary - VRF vrf1
BGP version - 4
local-as - 200
Identifier - 0.0.0.6
Decision state - Idle
The total number of routes is 1
BGPv6 NEIGHBOR INFO :
NEIGHBOR RMTAS STATE HLDTM KPALV HLDCFG KPCFG WGHT CONRTY ADVINT
2001:DB8:0:0:0:0:0:ffff 50 Established 180 60 180 60 100 120 5
Total bgpv6 neighbors: 1
BGP CONFEDERATION INFO :
confederation identifier 0
confederation peer as
BGPv6 NETWORK INFO :
BGPv6 Networks - VRF vrf1
The following table defines parameters for the show bgp ipv6 summary command.
Variable |
Value |
vrf |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids |
Specifies a range of VRFs by ID number (the ID ranges from 0–255). |
