Configure route advertisement in IPv6 on the management port for neighbor discovery (ND).
This procedure supports Layer 2 or Layer 3 route advertisement on VSP 8600 Series only.
Switch:1(config-if)#ipv6 nd dad-ns 2 Switch:1(config-if)#ipv6 nd hop-limit 2
Switch:1#show ipv6 nd interface mgmtethernet mgmt
Mgmt Ipv6 Nd
IFID MGMT-IF RTR-ADV MAX-INT MIN-INT LIFETIME MANAG OTHER DAD-NS MTU HOP REACHABLE RETRANSMIT
FLAG CONF LIMIT TIME TIME
64 mgmt False 600 200 0 False False 2 0(d) 2(s) 0(d) 0(d)
Note: (s)= Set, (d)= Default, (i)= inherit.
1 out of 5 Total Num of IPv6 ND Entries displayed.
Variable definitions
Use the data in the following table to use the ipv6 nd command.
Variable |
Value |
dad-ns <0–600> |
Specifies the number of neighbor solicitation messages for duplicate address detection (DAD). A value of 0 disables the DAD process on this interface. A value of 1 sends one advertisement without retransmissions. The default is 1. |
hop-limit <0–255> |
Specifies the current hop limit field sent in router advertisements from this interface. The value must be the current diameter of the Internet. A value of zero indicates that the advertisement does not specify a hop-limit value. The default is 64. |
