This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure remote IS-IS Multi-area SPB nickname for a specific SPBM instance on the switch.
Configuring remote IS-IS Multi-area SPB nickname for SPBM instance:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis remote Switch:1(config-remote)spbm 4 nick-name 1.11.16
What to do next
To verify the configuration, see Display the Remote IS-IS SPBM Nickname Configuration.
The following table defines parameters for the spbm command.
Variable | Value |
<1-100> |
Specifies the SPBM instance on the remote IS-IS interface. |
nick-name<x.xx.xx> |
Specifies a nickname for the remote IS-IS SPBM Multi-area SPB instance. The value is 2.5 bytes in the format <x.xx.xx>. |
