View application host statistics to see traffic statistics by application protocol for each host.
Switch:1# show rmon application-host-stats ?
WORD<1-64> Select one of these application protocols
{TCP|UDP|FTP|TELNET|HTTP|RLOGIN|SSH|TFTP|SNMP|HTTPS}
Switch:1# show rmon application-host-stats FTP
Rmon Application Host Stats
HOSTADDR INPKT OUTPKT INOCT OUTOCT CREATETIME
192.0.2.10 0 0 0 0 10/09/15 17:29:54
Protocol support can vary across platforms.
The following table defines parameters for the show rmon application-host-stats command.
| Variable | Value |
WORD<1–64> |
Specifies one of the following application protocols: TCP, UDP, FTP, TELNET, HTTP, rlogin, SSH, TFTP, SNMP, HTTPS. Note:
Exception: the rlogin application is only supported on VSP 8600 Series. RMON2 counts application packets received on any platform on which the application is not enabled or supported, before dropping them. |
