Configure ACE destination port entries to have the filter look for packets with a specific destination port.
The ACE exists.
The ACL exists.
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select the appropriate ACL.
- Click ACE.
- Select the appropriate ACE.
- Click Proto.
- Click the Destination Port tab.
- Click Insert.
- Specify the operator for the destination port.
- Specify the port number or port list to match.
- Click Insert.
Destination Port field descriptions
Use the data in the following table to use the Destination Port tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits. |
Port |
Specifies the port number. As noted at the bottom of the tab, potential entries include 0–65535, echo, ftpdata, ftpcontrol, ssh, telnet, dns, http, h.323, and undefined. |
OperMask |
Specifies the mask parameter, {0-0xFFFF}. |
