This procedure only applies to VSP 4900 Series.
Display the configured speed on all VIM ports.
Some VIMs must operate with all ports at the same speed, while others can operate with ports at different speeds. For more information, see VOSS Release Notes. The show sys vim-speed command is supported only on VIMs that must operate with all ports at the same speed. An error message displays if you run the command with an unsupported VIM installed.
Install the VIM before performing this procedure.
Use this procedure to display the configured speed of all ports in a multi-port VIM.
show sys vim-speed
