This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure Multi-area SPB layer 2 redistribution.
- Select MultiArea.
- Select the L2 ISID Redist tab.
- Select Insert.
- Configure the layer 2 I-SID redistribution parameters.
- Select Insert.
L2 Redistribute Field Descriptions
Use the data in the following table to use the L2 Redistribute tab.
Name | Description |
Type |
Specifies the layer 2 Redistribution type. |
Permit |
Configures the Multi-area SPB layer 2 I-SID redistribution policy as permit or deny. |
ExceptListName |
Configures the name of layer 2 I-SID list. The system does not apply the Multi-area SPB layer 2 I-SID redistribution policy to I-SID values or the range of I-SID values in the layer 2 I-SID list. |
