To access EDM, enter one of the following addresses in your web browser:
http://<A.B.C.D>
https://<A.B.C.D>
Where <A.B.C.D> is the device IP address.
Ensure you use a supported browser version. For more information about supported browsers, see Supported Browsers.
Important
You must enable the web server from CLI to enable HTTP access to the EDM. If you want HTTP access to the device, you must also disable the web server secure-only option. The web server secure-only option, allowing for HTTPS access to the device, is enabled by default. Take the appropriate security precautions within the network if you use HTTP.
EDM access is available to read-write users only.
If you experience any issues while connecting to the EDM, check the proxy settings. Proxy settings may affect EDM connectivity to the switch. Clear the browser cache and do not use proxy when connecting to the device. This should resolve the issue.
