If you configure the switch to operate in v2-v3 compatibility mode, the switch supports all IGMPv2 and v3 messages. The switch parses the group address of the messages. If the group address is out of SSM range and it is a v3 message, the switch drops the message. If it is a v2 message, IGMP snoop processes handle the message.
To troubleshoot issues with the IGMPv3 backwards compatibility feature, perform the following procedure.
Display the configured SSM static channels and display the configured SSM group range:
Switch:1#show ip igmp ssm-map
Igmp Ssm Channel - GlobalRouter
GROUP SOURCE MODE ACTIVE STATUS
233.252.0.1 192.0.2.200 dynamic false enabled
233.252.0.2 192.0.2.200 dynamic false enabled
233.252.0.3 192.0.2.200 dynamic false enabled
233.252.0.4 192.0.2.200 dynamic false enabled
233.252.0.5 192.0.2.200 dynamic false enabled
233.252.0.6 192.0.2.200 dynamic false enabled
233.252.0.7 192.0.2.200 dynamic false enabled
233.252.0.8 192.0.2.200 dynamic false enabled
233.252.0.9 192.0.2.200 dynamic false enabled
233.252.0.10 192.0.2.200 dynamic false enabled
10 out of 10 entries displayed
Igmp Ssm Global - GlobalRouter
DYNAMIC LEARNING SSM GROUP RANGE
enable 232.0.0.0/255.0.0.0
