Configure a circuitless IP (CLIP) interface to provide a virtual interface that is not associated with a physical port. You can use a CLIP interface to provide uninterrupted connectivity to your device.
For scaling information and for information on the maximum number of CLIP interfaces you can configure on your device, see VOSS Release Notes.
Create a CLIP interface.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface loopback 3 Switch:1(config-if)#ip address 23.23.23.23 255.255.255.0 name ExtNet Switch:1>show ip interface ============================================================================================= IP Interface - GlobalRouter ============================================================================================= INTERFACE IP NET BCASTADDR REASM VLAN BROUTER IPSEC IP ADDRESS MASK FORMAT MAXSIZE ID PORT STATE NAME --------------------------------------------------------------------------------------------- Port1/2 10.3.4.2 255.255.255.0 ones 1500 3 true disable address1 Clip1 1.2.3.4 255.255.0.0 ones 1500 -- false disable Clip2 2.3.4.5 255.255.255.0 ones 1500 -- false disable Clip23 23.23.23.23 255.255.255.0 ones 1500 -- false disable ExtNet Vlan2 192.0.2.5 255.255.255.0 ones 1500 2 false disable Vlan55 55.55.55.55 255.255.255.0 ones 1500 55 false disable Boston All 6 out of 6 Total Num of IP interfaces displayed
Use the data in the following table to use the ip commands.
Variable |
Value |
address [ <1-256> ] <A.B.C.D/X> [vrf WORD<1-16> ][name WORD<0-64] |
Specifies the IP address for the CLIP interface. <1-256> specifies the interface. <A.B.C.D/X> specifies the IP address and mask (0–32). vrf WORD<1-16> specifies an associated VRF by name. The no form of this command is no ip address [<1-32>] <A.B.C.D> [vrf WORD<1-16>]. name WORD<1-16> specifies a name for the IP address. |
area <1-256> <A.B.C.D> [vrf WORD<1-16> ] |
Designates an area for the CLIP interface. vrf WORD<1-16> specifies an associated VRF by name The default form of this command is default ip area <1-256> <A.B.C.D> [vrf WORD<1-16>]. The no form of this command is no ip area <1-256> vrf WORD<1-16>]. |
