Configure IPv6 network addresses to determine the network addresses that BGP advertises. The allowed addresses determine the BGP networks that originate from the switch.
To configure allowed IPv4 networks, see Configure Allowed Networks.
- Click BGP+.
- Click the Network tab.
- Click Insert.
- Configure the network address, prefix length and metric.
- Click Insert.
Network field descriptions
Use the data in the following table to use the Network tab.
| Name | Description |
| NetworkAfAddr | Specifies the network prefix that BGP advertises. The default is none. |
| NetworkAfPrefixLen | Specifies the network prefix length. The default is none. |
| NetworkAfMetric | Specifies the metric used when an update is sent for the routes in the network table. The metric configures the MED for the routes advertised to EBGP peers. The range is 0 to 65535. The default is 0. |
