- display the configured key details for given key name.
- display the digital certificate for the given certificate index or list all the certificate details from the local store if the certificate index is not specified.
- display the CA details for given trustpoint CA name or list all the CA details from the local store if the CA name is not specified.
- Select Certificate.
- Select the Certificate tab.
Certificate Field Descriptions
Use the data in the following table to use the Certificate tab.
| Name | Description |
| Type | Specifies the certificate type. |
| VersionNumber | Specifies the version number of the certificate for the subject as issued by the Certificate Authority. |
| SerialNumber | Specifies the serial number of the certificate for the subject as issued by the Certificate Authority. |
| IssuerName | Specifies the name of the issuer of the certificate for the subject as issued by the Certificate Authority. |
| ValidStartPeriod | Specifies the start date of the validation period of the certificate for the subject as issued by the Certificate Authority. |
| ValidEndPeriod | Specifies the last date of the validation period of the certificate for the subject as issued by the Certificate Authority. |
| CertificateSignatureAlgorithm | Specifies the algorithm used for the signature of the issuer on the certificate for the subject as issued by the Certificate Authority. |
| CertificateSignature | Specifies the signature of the issuer on the certificate for the subject as issued by the Certificate Authority. |
| Subject | Specifies the details of the subject on its certificate as issued by Certificate Authority. |
| SubjectPublicKeyAlgorithm | Specifies the algorithm used to generate the public key of the subject for the certificate issued by the Certificate Authority. |
| SubjectPublicKey | Specifies the public key of the subject used for the Certificate Signing Request. |
| HasBasicConstraint | Specifies whether the certificate contains any basic certificate constraint or not. |
| HasKeyUsage | Specifies whether the certificate contains basic key usage constraint or not. |
| IsCa | Specifies whether the certificate is a ca certificate or not. |
| KeyUsage | Specifies the purpose of the key used in the certificate. It is
represented in the form of bits as follows:
| Status | Specifies the status of the certificate. |
| Installed | Specifies whether the certificate is installed or not. |
| CdpUrl | Specifies the CDP URL present in the Digital Certificate Extensions field. |
| OcspUrl | Specifies the OCSP URL present in the Digital Certificate AIA field. |
| ExtendedKeyUsage | Indicates the purpose for which the key is used in addition to or in place of the basic purposes indicated in the key-usage field of the certificate. |
| RevocationStatus Note: Exception: not supported on
                                        VSP 8600
					Series. | Specifies the revocation status of the certificate. |
