This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure Multi-area SPB layer 3 redistribution in the remote area.
- Select MultiArea.
- Select the L3 Redist Remote tab.
- Select Insert.
- In the VrfId field, type the Virtual Router Forwarding ID.
- In the Type field, select the layer 3 redistribution type.
- Optional: In the RoutePolicy field, type the name of the redistribution policy.
- Select Enable.
- In the Apply field, select apply.
- Select Insert.
L3 Redist Remote Field Descriptions
Use the data in the following table to use the L3 Redist Remote tab.
Name | Description |
VrfId |
Specifies the Virtual Router Forwarding ID. |
Type |
Specifies the layer 3 redistribution type. The options are:
RoutePolicy |
Associates a route policy to a specific layer 3 redistribution entry in the remote area. |
Enable |
Enables layer 3 redistribution in the remote area. The default value is disabled. |
Apply |
Applies the Multi-area SPB layer 3 redistribution filters in the remote area. The default value is noAction. |
