This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the remote hello interval to change how often hello packets are sent out from an interface level.
Configuring the remote hello interval on port 1/3:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/3 Switch:1(config-if)#isis remote l1-hello-interval 1
The following table defines parameters for the isis remote l1-hello-interval command.
Variable | Value |
<1-600> |
Configures the Level 1 remote hello interval. The default value is 9 seconds. |
