This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure Multi-area SPB Distributed Virtual Routing (DvR) backbone redistribution on the switch.
Configuring Multi-area SPB DvR backbone redistribution:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis Switch:1(config-isis)multi-area dvr redistribute backbone
What to do next
To verify the configuration, see Display IS-IS Multi-area SPB DvR Configuration.
