View RMON control tables to see the data source for both network layer and application layer host statistics.
Switch:1# show rmon ctl-table ================================================================================ Rmon Control Table ================================================================================ ================================================================================ Protocol Directory Table ================================================================================ IDX PROTOCOL ADDRMAPCFG HOSTCFG MATRIXCFG OWNER -------------------------------------------------------------------------------- 1 IP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 2 TCP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 3 UDP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 4 FTP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 5 SSH SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 6 TELNET SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 7 HTTP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 8 RLOGIN SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 9 TFTP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 10 SNMP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 11 HTTPS SUPPORTED SUPPORTED NOT SUPPORTED Switch-1 ================================================================================ Protocol Distribution Control Table ================================================================================ IDX DATASOURCE DROPFRAMES CREATETIME OWNER -------------------------------------------------------------------------------- 1 0.0.0.0 0 09/22/15 19:29:13 Switch-1 ================================================================================ Address Map Control Table ================================================================================ IDX DATASOURCE DROPFRAMES OWNER -------------------------------------------------------------------------------- 1 0.0.0.0 0 Switch-1 ================================================================================ Host Control Table ================================================================================ IDX DATASOURCE NHDROPFRAMES AHDROPFRAMES OWNER -------------------------------------------------------------------------------- 1 0.0.0.0 0 0 Switch-1
Protocol support can vary across platforms.
