Configure mesh groups to reduce SA flooding. A mesh group does not forward SA messages to other group members in the same mesh group. The originator, which is also a mesh group member, forwards SA messages to all group members. Create MSDP mesh groups from a group of meshed MSDP speakers from a domain. Do not create MSDP peerings between Controllers within the same SPB domain.
- Click MSDP.
- Click the Mesh Group tab.
- Click Insert.
- In the Name field, type a name for the mesh group.
- In the PeerAddress field, type the IP address of the peer to add the mesh group.
- Click Insert.
Mesh Group field descriptions
Use the data in the following table to use the Mesh Group tab.
Name |
Description |
Name |
Specifies the mesh group ID; the name of the mesh group from 1-64 characters. |
PeerAddress |
Specifies the IP address of the MSDP router that is the peer. |
