Display relay information to show relay information about DHCP routes and counters.
For scaling information on DHCP Relay forwarding (IPv4 or IPv6), see VOSS Release Notes.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1#show ip dhcp-relay interface ================================================================================ Port Dhcp ================================================================================ PORT VRF MAX MIN ALWAYS CIRCUIT REMOTE TRUST NUM NAME ENABLE HOP SEC MODE BCAST ID ID CIRC -------------------------------------------------------------------------------- ================================================================================ Vlan Dhcp ================================================================================ VLAN VRF MAX MIN ALWAYS CIRCUIT REMOTE TRUST ID NAME ENABLE HOP SEC MODE BCAST ID ID CIRC -------------------------------------------------------------------------------- All 0 out of 0 of Vlan Dhcp Entries displayed
Variable definitions
Use the data in the following table to use the show ip dhcp-relay command.
Variable |
Value |
vrf WORD<1-16> |
The name of the VRF. |
vrfids WORD<0-512> |
The ID of the VRF. The value is an integer in the range of 0–512. |
Use the data in the following table to use the show ip dhcp-relay interface command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
[vlan <1-4059>] |
[vrf WORD<1-16>] |
Specifies the name of the VRF. |
[vrfids WORD<0-512>] |
Specifies the ID of the VRF. The value is an integer from 0– 512. |
