Use the following procedure to view or clear statistics of the number of packets mirrored into I-SID on the mirroring BEB.
- Click General.
- Click the Isid-Mirroring Stats tab.
Isid-Mirroring Stats Field Descriptions
Use the data in the following table to use the Isid-Mirroring Stats tab.
Name |
Description |
Index |
Specifies the entry that contains Fabric RSPAN statistics information. |
MonitorIsid |
Specifies the actual monitor I-SID value to which the packets are mirrored. |
MirroredPackets |
Specifies the number of packets mirrored into I-SID on the mirroring BEB. |
ClearStats |
Clears the Fabric RSPAN statistics. |
