Perform this procedure to traceroute to an IP address on Fabric IPsec Gateway Virtual Machine (VM).
Traceroute to IP address.Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> traceroute 192.0.2.100
The following table defines parameters for the traceroute command.
| Variable | Value |
| {A.B.C.D} | Specifies the IP address to initiate traceroute to. |
