Use the following procedure to change the Connectivity Association (CA) to which a port is associated.
Ensure that the new CA is created at the global level. For information about configuring a CA, see Configure a Connectivity Association.
Change the CA to which a port is associated:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabit 1/2 Switch:1(config-if)#no macsec enable Switch:1(config-if)#macsec connectivity-association caname12 Switch:1(config-if)#macsec enable
The following table defines parameters for the macsec command.
| Variable | Value |
| connectivity-association WORD<5–16> | Specifies the connectivity-association name as an alpha-numeric ASCII string up to 16 characters long. The device uses this value for the connectivity-association key name (CKN). Tip:
                                 Configure the CKN in multiples of 4 characters to avoid MKA interoperability issues between VOSS switches and EXOS or Switch Engine switches. For example, Macsecma (8 chararcters) or Macsecmka123 (12 characters) are valid, but Macsec (6 characters) is not valid. |
The following table defines parameters for the interface gigabitethernet command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...]} | Specifies the port to associate with the connectivity association (CA). Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
