Use this procedure to display IP Multicast over Fabric Connect summary information.
Display IP Multicast over Fabric Connect global configuration information:
Switch:1>enable
Switch:1#show isis spbm multicast
multicast : enable
fwd-cache-timeout(seconds) : 210
Switch:1#show isis spb-mcast-summary
SPB multicast - Summary
SCOPE SOURCE GROUP DATA LSP HOST
I-SID ADDRESS ADDRESS I-SID BVID FRAG NAME
GRT 192.0.2.102 233.252.0.1 16000001 63 0x0 DIST5A
Switch:1>show ip mroute route
Mroute Route - GlobalRouter
GROUP SOURCE SRCMASK UPSTREAM_NBR IF EXPIR PROT
233.252.0.1 0.0.0.0 0.0.0.0 0.0.0.0 V3 30 spb-access
233.252.0.1 192.0.2.102 255.255.255.0 0.0.0.0 - 0 spb-network
233.252.0.2 0.0.0.0 0.0.0.0 0.0.0.0 V2 30 pimsm
225.1.1.1 198.51.100.99 255.255.255.0 0.0.0.0 V3 173 spb-pim-gw
Total 4
The following table defines parameters for the show isis spb-mcast-summary command.
Variable |
Value |
count |
Displays the total number of SPB multicast entries. |
host-name WORD<0–255> |
Displays the IP Multicast over Fabric Connect summary information for a specific host-name. |
lspid <xxx.xxx.xxx.xx-xx> |
Displays the IP Multicast over Fabric Connect summary information for the specified LSP ID that you enter in xxx.xxx.xxx.xx-xx — 8 byte format. |
The following table defines parameters for the show ip mroute route command.
Variable |
Value |
vrf WORD<1–32> |
Specifies a VRF. |
vrfids WORD<0–255> |
Specifies the VRF ID |
