Use this procedure to view the LLDP neighbor information.
- Click LLDP.
- Click the Neighbor tab.
Neighbor Field Descriptions
Use the data in the following table to use the Neighbor tab.
| Name | Description |
| TimeMark | Indicates the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
| LocalPortNum | Identifies the port on which the remote system information is received. |
| Index | Indicates a particular connection instance that is unique to the remote system. |
| ProtocolType | Indicates whether the entry protocol is CDP or LLDP. |
| SysName | Indicates the name of the remote system. |
| IpAddress | Indicates the neighbor‘s IP address. |
| PortIdSubType | Indicates the type of encoding used to identify the remote port. |
| PortId | Indicates the remote port ID. |
| PortDesc | Indicates the remote port description. |
| ChassisIdSubtype | Indicates the type of encoding used to identify the remote system chassis.
| ChassisId | Indicates the chassis ID of the remote system. |
| SysCapSupported | Identifies the system capabilities supported on the remote system. |
| SysCapEnabled | Identifies the system capabilities enabled on the remote system. |
| SysDesc | Indicates the description of the remote system. |
