Use the following procedure to display the SPB-PIM Gateway VLAN information.
- Click VLANs.
- Select a row from the VLAN and click the IP tab.
- Click the SPB-PIM-GW tab.
SPB-PIM-GW field descriptions
Use the data in the following table to use the SPB-PIM-GW tab.
Name |
Description |
OperState |
Displays the current operational state of this SPB-PIM Gateway interface. |
Address |
Displays the primary IP address of this router on this SPB-PIM Gateway interface. |
AddressMask |
Displays the primary IP address mask of this router on this SPB-PIM Gateway interface. |
HelloInterval |
Configures the PIM HELLO transmission interval. This SPB-PIM Gateway VLAN level interval setting overrides the inherited global SPB-PIM Gateway HELLO interval setting. Setting the HELLO Interval to 0 causes the neighbors to never expire its neighborship with this local SPB-PIM Gateway interface. |
JoinPruneInterval |
Configures the PIM JOIN PRUNE transmission interval. This SPB-PIM Gateway VLAN level interval setting overrides the inherited global level JOIN PRUNE transmission interval setting. |
