Use the following procedure to display the active Controllers and Gateways in the SPBM domain.
- Click SPB-PIM-GW.
- Click the Node tab.
Node field descriptions
Use the data in the following table to use the Node tab.
Name |
Description |
MacAddress |
Shows the MAC address of the active node. |
HostName |
Shows the host name of the active node. |
RoleType |
Shows the role of the active node: either gateway, controller, or both. |
