Display individual LACP statistics for specific ports to manage network performance.
Slot and port information can differ depending on hardware platform.
View LACP statistics:
Switch:1>enable Switch:1#show interfaces gigabitethernet statistics lacp ================================================================================ Port Stats Lacp ================================================================================ PORT TX RX TX RX TX RX RX RX NUM LACPDU LACPDU MARKERPDU MARKERPDU MARKERRESPPDU MARKERRESPPDU UNKNOWN ILLEGAL -------------------------------------------------------------------------------- 1/39 0 0 0 0 0 0 0 0 1/40 0 0 0 0 0 0 0 0 2/37 0 0 0 0 0 0 0 0 2/38 0 0 0 0 0 0 0 0
Use the data in the following table to use the show interfaces GigabitEthernet statistics lacp command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
