Perform this procedure to enable Energy Saver globally on the switch. You can optionally configure PoE power savings, to power off low priority PoE devices during off-peak times.
You must enable Energy Saver on individual ports.
You must create an Energy Saver schedule.
Switch:1>enable Switch:1#configure terminal
Switch:1(config)#energy-saver poe-power-saving
Switch:1(config)#energy-saver enable
The following table defines parameters for the energy-saver command.
Variable |
Value |
enable |
Enables Energy Saver feature. The default is disabled. |
poe-power-saving |
Enables PoE power saving. The default is disabled. |
