This procedure only applies to the VSP 7400 Series.
Configure IP Shortcuts on the boundary nodes.
Perform this procedure to configure Multi-area SPB IPv4 unicast redistribution on the switch.
Configuring Multi-area SPB IPv4 unicast redistribution for home to remote direction:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis Switch:1(config-isis)#multi-area ip redistribute unicast home-to-remote Switch:1(config-isis)#multi-area ip redistribute unicast home-to-remote route-map test Switch:1(config-isis)#multi-area ip redistribute unicast home-to-remote enable Switch:1(config-isis)#show isis multi-area ip redistribute home-to-remote ================================================================================ ISIS Multiarea Redistribute List for ip unicast - GlobalRouter ================================================================================ DIRECTION ENABLE RPOLICY -------------------------------------------------------------------------------- home-to-remote TRUE test -------------------------------------------------------------------------------- Switch:1(config-isis)#isis multi-area ip apply redistribute unicast home-to-remote
The following table defines parameters for the multi-area ip redistribute unicast and the isis multi-area ip apply redistribute unicast commands.
Variable | Value |
enable |
Enables Multi-area SPB IPv4 unicast redistribution. |
home-to-remote |
Specifies the IPv4 unicast redistribution configuration for home to remote direction. |
remote-to-home |
Specifies the IPv4 unicast redistribution configuration for remote to home direction. |
route-map WORD<1-64> |
Specifies the name of the route policy. |
vrf WORD<1-16> |
Specifies the unicast redistribution configuration for specific VRF instance. |
