Unable to Log On by any Means
If you cannot log on by any means, perform the following steps.
Rlogin is only supported on VSP 8600 Series.
Check if you enabled both TACACS+ and RADIUS on the switch:
Switch:1>enable Switch:1(config)#show tacacs Global Status: global enable : false authentication enabled for : cli accounting enabled for : none authorization : disabled User privilege levels set for command authorization : None Server: create : Prio Status Key Port IP address Timeout Single Source SourceEnabled Primary NotConn ****** 3 192.0.2.254 30 true 5.5.5.5 true Backup NotConn ****** 47 198.51.100.1 10 false 0.0.0.0 false Switch:1>show radius acct-attribute-value : 193 acct-enable : false acct-include-cli-commands : false access-priority-attribute : 192 auth-info-attr-value : 91 command-access-attribute : 194 cli-commands-attribute : 195 cli-cmd-count : 40 cli-profile-enable : false enable : false igap-passwd-attr : standard igap-timeout-log-fsize : 512 maxserver : 10 mcast-addr-attr-value : 90 supported-vendor-ids : 1584, 562, 1916 secure-flag : false
Check if the administrative and operation status of the port is up:
Switch:1#show interface gigabitethernet 1/2 ================================================================================ Port Interface ================================================================================ PORT LINK PORT PHYSICAL STATUS NUM INDEX DESCRIPTION TRAP LOCK MTU ADDRESS ADMIN OPERATE -------------------------------------------------------------------------------- 1/2 257 1000BaseTX true false 1950 00:24:7f:a1:70:61 up up ================================================================================ Port Name ================================================================================ PORT OPERATE OPERATE OPERATE NUM NAME DESCRIPTION STATUS DUPLEX SPEED VL AN -------------------------------------------------------------------------------- 1/2 1000BaseTX up full 1000 Ta gged ================================================================================ Port Config ================================================================================ PORT DIFF-SERV QOS MLT VENDOR --More-- (q = quit)
Check if the switch has a route configured to the server network:
Switch:1(config)#show ip route ========================================================================================== IP Route - GlobalRouter ========================================================================================== NH INTER DST MASK NEXT VRF/ISID COST FACE PROT AGE TYPE PRF ------------------------------------------------------------------------------------------ 198.51.100.1 255.255.255.255 192.0.2.65 GlobalRouter 1 100 OSPF 0 IB 125 198.51.100.5 255.255.255.255 192.0.2.5 - 1 0 LOC 0 DB 0 198.51.100.13 255.255.255.255 GlobalRouter 10 1000 ISIS 0 IBS 7 198.51.100.200 255.255.255.255 GlobalRouter 10 1000 ISIS 0 IBS 7 4 out of 4 Total Num of Route Entries, 4 Total Num of Dest Networks displayed. -------------------------------------------------------------------------------- TYPE Legend: I=Indirect Route, D=Direct Route, A=Alternative Route, B=Best Route, E=Ecmp Rout e, U=Unresolved Route, N=Not in HW, F=Replaced by FTN, V=IPVPN Route, S=SPBM Route PROTOCOL Legend: v=Inter-VRF route redistributed
Check if the Segmented Management
Instance has a route configured to the server
network:
Switch:1(config)#show mgmt ip route ========================================================================================== Mgmt IPv4 Route Information - Table main ========================================================================================== DEST/MASK NEXTHOP METRIC INTERFACE TYPE ------------------------------------------------------------------------------------------ 198.51.100.0/16 198.51.100.1 300 Mgmt-oob1 STATIC 198.51.100.0/23 0.0.0.0 1 Mgmt-oob1 LOCAL 192.0.2.0/8 192.0.2.1 300 Mgmt-oob1 STATIC 3 out of 3 Total Num of mgmt ip route displayed ------------------------------------------------------------------------------------------
