Use this procedure to view global LLDP information, to know which LLDP settings and parameters are configured.
View global LLDP information:
Switch:1#show lldp 802.1ab Configuration: ------------------------------------ TxInterval: 30 TxHoldMultiplier: 4 ReinitDelay: 1 TxDelay: 1 NotificationInterval: 5
View the LLDP local system data on the switch:
Switch:1#show lldp local-sys-data ====================================================================== LLDP Local System Data ====================================================================== ChassisId: MAC Address b0:ad:aa:4c:54:00 SysName : LLDP agent SysDescr : VSP-4450GSX-PWR+ (6.0.1.0) BoxType: VSP-4450 SysCap : Br / Br ---------------------------------------------------------------------- Capabilities Legend: (Supported/Enabled) B= Bridge, D= DOCSIS, O= Other, R= Repeater, S= Station, T= Telephone, W= WLAN, r= Router
View the LLDP neighbor information. You can also view this on a specific port.
Switch:1#show lldp neighbor =============================================================================== LLDP Neighbor =============================================================================== Port: 1/28 Index : 1 Time: 0 day(s), 01:16:25 Protocol : LLDP ChassisId: MAC Address a4:25:1b:52:54:00 PortId : MAC Address a4:25:1b:52:54:1b SysName : BEB SysCap : Br / Br PortDescr: VSP8404 - Gbic1000BaseT Port 1/28 SysDescr : VSP8404 (4.5.0.0) Address : 192.0.2.47 ------------------------------------------------------------------------------- Total Neighbors : 1 ------------------------------------------------------------------------------- Capabilities Legend: (Supported/Enabled) B= Bridge, D= DOCSIS, O= Other, R= Repeater, S= Station, T= Telephone, W= WLAN, r= Router
View the LLDP neighbor summary of all ports on the switch. You can also view this on a specific port.
The EDM tab (
displays only IPv4 addresses. Use CLI to see both IPv4 and IPv6.Switch:1#show lldp neighbor summary ======================================================================================================================== LLDP Neighbor Summary ======================================================================================================================== LOCAL IP/IPv6 CHASSIS REMOTE PORT PROT ADDR ID PORT SYSNAME SYSDESCR ------------------------------------------------------------------------------------------------------------------------ 1/4 LLDP 0.0.0.0 f8:15:47:e1:dd:00 f8:15:47:e1:dd:06 VSP-4450GSX-~ VSP-4450GSX-PWR+ (6.0.1.0) 1/12 LLDP 192.0.2.77 a4:25:1b:53:6c:00 a4:25:1b:53:6c:28 VSP-7254XTQ VSP-7254XTQ (6.0.0.0) 1/13 LLDP 192.0.2.34 00:14:0d:e3:40:00 00:14:0d:e3:40:c1 ERS-8606 ERS-8606 (7.2.10.1) 1/14 LLDP 192.0.2.78 a4:25:1b:52:34:00 a4:25:1b:52:34:28 VSP-7254XSQ VSP-7254XSQ (6.0.0.0) 1/24 LLDP 192.0.2.94 00:13:65:a3:8c:00 00:13:65:a3:8c:18 Ethernet Routing Switch 5520-~ 1/25 CDP 192.0.2.89 -- FastEthernet2/0/5 cisco3750.Tr~ cisco WS-C3750-48P running on~ 1/27 CDP 0.0.0.0 -- FastEthernet3/0/6 Switch cisco WS-C3750-48TS running o~ 1/48 LLDP 192.0.2.76 b0:ad:aa:4e:dc:00 b0:ad:aa:4e:dc:68 VSP-8404 VSP-8404 (6.0.0.0) ------------------------------------------------------------------------------------------------------------------------ Total Neighbors : 8
View the LLDP administrative status of all ports on the switch. You can also view this on a specific port.
Switch:1#show lldp port ====================================================================== LLDP Admin Port Status ====================================================================== ---------------------------------------------------------------------- Port AdminStatus ConfigNotificationEnable CdpAdminState ---------------------------------------------------------------------- 1/1 txAndRx disabled disabled 1/2 txAndRx disabled disabled 1/3 txAndRx disabled disabled 1/4 txAndRx disabled disabled ... ...
View the LLDP reception statistics. You can also view this on a specific port.
Switch:1#show lldp rx-stats ============================================================================= LLDP Rx-Stats ============================================================================= Port Frames Frames Frames TLVs TLVs AgeOuts Num Discarded Errors Total Discarded Unsupported (Non FA) (Non FA) ----------------------------------------------------------------------------- 1/1 0 0 0 0 0 0 1/2 0 0 0 0 0 0 1/3 0 0 0 0 0 0 1/4 0 0 0 0 0 0 ... ...
View the LLDP statistics:
Switch:1#show lldp stats ============================================================== LLDP Stats ============================================================== Inserts Deletes Drops Ageouts -------------------------------------------------------------- 4 0 0 0 --------------------------------------------------------------
View the LLDP transmission statistics:
Switch:1#show lldp tx-stats ====================================================================== LLDP Tx-Stats ====================================================================== PORT NUM FRAMES ---------------------------------------------------------------------- 1/1 95 1/2 95 1/3 95 1/4 95 1/5 95 ... ...
Display LLDP-MED local system data:
Switch:1#show lldp local-sys-data med ====================================================================================== LLDP Local System Data ====================================================================================== ChassisId: MAC Address d4:78:56:f1:65:00 SysName : VSP-4450GSX-PWR+ SysDescr : VSP-4450GSX-PWR+ (w.x.y.z) SysCap : Br / Br MED Capabilities: CNLSI MED Device Type: Network Connectivity Device MED Power Device Type: PSE Device HWRev: 03 FWRev: VU-Boot 2012.04-00034-g57194a8 SWRev: v5.7.3.005 SerialNumber: 16JP1160E51D ManufName: Extreme Networks. ModelName: VSP-4450GSX-PWR+ Asset ID: 16JP1160E51D -------------------------------------------------------------------------------------- Port: 1/1 MED Enabled Capabilities: CNLI MED Network Policy: Application Type: Voice VLAN ID: 412 L2 Priority: 3 DSCP Value: 57 Tagging: Tagged Vlan Policy defined Application Type: Voice-Signaling VLAN ID: 7 L2 Priority: 6 DSCP Value: 24 Tagging: Tagged Vlan Policy defined MED Location - Coordinate-based LCI: Latitude: +12.3 (degrees) North Longitude: +42 (degrees) East Altitude: +45 (meters) Datum: World Geodesic System (WGS84) MED Location - Civic Address LCI: Country code: RO Country: Romania City: Bucuresti Block: 12 Street: Calea Floreasca Floor: 3 MED Location - Emergency Call Service ELIN: ECS ELIN: 121416182022 MED Extended Power via MDI: Power Value: 16.0 Watt Power Type: PSE Power Source: Primary Power Priority: Low -------------------------------------------------------------------------------------- Capabilities Legend: (Supported/Enabled) B= Bridge, D= DOCSIS, O= Other, R= Repeater, S= Station, T= Telephone, W= WLAN, r= Router MED Capabilities Legend: (Supported/Enabled) C= Capabilities, N= Network Policy; L= Location Identification; I= Inventory; S= Extended Power via MDI - PSE; D= Extended Power via MDI - PD.
The following table defines parameters for the show lldp command.
Variable |
Value |
local-sys-data |
Displays the LLDP local system data. |
neighbor [summary] [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the LLDP neighbor system information. You can also view this on a specific port. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
port [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the LLDP administrative status of a port or all ports on the switch. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
rx-stats [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the LLDP reception statistics on all ports on the switch, or on a specific port. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
stats |
Displays the LLDP statistics. |
tx-stats [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the LLDP transmission statistics on all ports on the switch or on a specific port. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
