Perform this procedure to view location information of remote LLDP-MED on specific ports.
- Click Port MED.
- Click the Neighbor Location tab.
Neighbor Location Field Descriptions
Name |
Description |
TimeMark |
Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
LocalPortNum |
Specifies the port on which the remote LLDP-MED information is received. |
Index |
Specifies the particular connection instance that is unique to the remote LLDP-MED. |
LocationSubType |
Specifies the subtype of the remote LLDP-MED location:
LocationInfo |
Specifies the location information of the remote LLDP-MED. |
