This procedure only applies to XA1400 Series.If you downgrade to an earlier release that does not support this feature, you must disable the feature and save the configuration. You must have a compatible configuration file if you downgrade to an earlier release.
enable
configure terminal
logical-intf isis <1–255>
Disable IPsec and IPsec fragementation before encryption and verify the configuration:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#logical-intf isis 2
Switch:1(config-isis-2-192.168.20.1)#no ipsec
Switch:1(config-isis-2-192.168.20.1)#no ipsec fragment-before-encrypt
Switch:1(config-isis-2-192.168.20.1)#ipsec
Switch:1(config-isis-2-192.168.20.1)#show isis logical-interface ipsec
ISIS Logical Interface IPSec
ID Status Auth-Method Auth-Key ESP Responder-Only Remote NAT IP Auth-Key-Len Compression Frag-before-encrypt
1 Enable RSA-SIG ****** aes128gcm16-sha256 False - 128 False False
1 out of 1 Total Num of Logical ISIS interfaces
IPSec Tunnel General Info
IPSec tunnel global source-ip-address : 203.0.113.1
ISIS IPSec Tunnels
ID IPSec source IP IPSec Dst Ip TUNNEL_NEXT_HOP
type address PORT/MLT VLAN VRF
1 global 203.0.113.1 100.100.100.6 Port1/6 100 GlobalRouter
