Use this procedure to configure organizational-specific TLVs for Link Layer Discovery Protocol (LLDP) Media Endpoint Devices (MED). LLDP MED TLVs are enabled by default.
Disable LLDP MED TLVs
Switch:1>enable Switch:1#config Configuring from terminal or network [terminal]? t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/2 Switch:1(config-if)#no lldp tx-tlv med inventory Switch:1(config-if)#no lldp tx-tlv med location
witch:1#show lldp tx-tlv med
                               LLDP port med tlvs
Port          Med        Network   Location  ExtendedPower Inventory
           Capabilities   Policy                ViaMDI
1/2        disabled      enabled   enabled   enabled      disabled
            Restore LLDP MED TLVs for transmission to their default value:
Switch:1>enable Switch:1#config Configuring from terminal or network [terminal]? t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/2 Switch:1(config-if)#default lldp tx-tlv med inventory Switch:1(config-if)#default lldp tx-tlv med med-capabilities
Switch:1#show lldp tx-tlv med
                               LLDP port med tlvs
1/1        enabled       enabled   enabled   enabled       enabled
1/2        enabled       enabled   enabled   enabled       enabled
The following table defines parameters for the lldp tx-tlv med command.
 Variable  |
 Value  |
 extendedPSE  |
 Specifies the extended power-via-MDI Media Endpoint Device (MED) transmission TLV. This TLV is applilcable for POE-capable switches only. The default is enabled on POE-capable switches only.  |
 inventory  |
                             Specifies the system capabilities MED transmission TLV. The default is enabled.  |
 location  |
                             Specifies the system description MED transmission TLV. The default is enabled.  |
 med-capabilities  |
                             Specifies the system name MED transmission TLV. The default is enabled.  |
                             network-policy  |
                             Specifies the network policy MED transmission TLV. The default is enabled.  |
