The system uses a per-interface state to adapt to all Auto-sense events. Each state transition determines background configuration on the port. The system does not display Auto-sense port configurations in the show running-config command or in the saved configuration file; instead use the show auto-sense commands to show global and port specific Auto-sense information..
The following flowcharts describe the system logic for Auto-sense port state detection, how the system configurations change the logic path, and the Auto-sense configuration results.
The vlan create CLI command examples are not applicable for DvR leaf switch configurations. DvR leaf switches create VLANs automatically.
